Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Hmm, I recall (?) Cisco used to use a default Tc of 25ms, and I also recall (?) newer IOS implementations changed the default to 4ms (this, I suspect, to better support VoIP).
Setting Bc to obtain an optimal Tc, depends on what your service needs are. If you're shaping to deal with a downstream bottleneck, and your doing QoS, traffic with tight timing requirements, generally a smaller Bc (and Tc) is required. This because, as you minimize Bc (and Tc), the shaper performs closer to a physical link of similar bandwidth. However, I believe this adds to processing load, so you want to avoid needlessly doing this. Personally, I either just go with the default or, if I set Bc, I've found a 10ms Tc usually works well.
BTW, when working with a rate limiter (or policer), as they don't queue over rate traffic, using a small Bc (and Tc) tends to drop (bursty) traffic.
