05-01-2014 05:55 AM - edited 03-04-2019 10:53 PM
Hello, I would like to verify the use of a traffic-shaping policy within an MQC. I was told that you need to apply a shaping policy in order for QoS to always be engaged and not simply during times of congestion. This apparently is critical when you have apps like VoIP.
On a similar note, i remember reading up on Ciscopress that you might NOT want to subject VoIP to any form of Shaping as this introdues delay and can cause Jitter.
Below is a sample config. If you can post an authoritative source on CCO that explains this I would greatly appreciate it.
-Mike
policy-map QoS-Policy
class realtime
priority 512
police 512000 conform-action transmit exceed-action drop
class preferred
bandwidth remaining percent 40
random-detect dscp-based
class missioncritical
bandwidth remaining percent 39
class trans-apps
bandwidth remaining percent 16
class general
class class-default
policy-map shape-20MB
class class-default
shape average 2000000
service-policy QoS-Policy
interface Serial0/0/0
service-policy output shape-20MB
Solved! Go to Solution.
05-01-2014 06:34 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Nope.
You only need to shape when you're dealing with a path where you know the end-to-end bandwidth is less the the egress interface's physical bandwidth and where you cannot manage congestion further downstream along the end-to-end path.
Semi-true.
The problem can be mitigated by decreasing the shaper's Tc. Also, if shaper doesn't account for L2 overhead (and I believe many do not), you'll need to shape "slower" than the nominal bandwidth. The major problem with the latter, L2 overhead varies, as a percentage, based on packet size. So, you can either allow for worst case, which will best guarantee VoIP service, but tends to give up much of the available bandwidth, or you can shape for average case, which will make VoIP latency and jitter more variable but usually not so much to exceed its service requirements.
You can also bypass shaping for some traffic, but then you need to shape all your other traffic even slower to guarantee the non-shaped traffic bandwidth is always available. As you're effectively reserving this bandwidth, it then becomes unavailable for your other traffic even when unused.
An example of the latter:
class preferred
class trans-apps
class general
class class-default
class realtime
priority 512
class class-default
shape average 1950000
NB: BTW, the above doesn't account for L2 overhead, and I wouldn't recommend it for other reasons, but it should show how you can bypass the shaper.
05-01-2014 10:09 AM
Disclaimer
Posting
Yes, and usually somewhere in the range 10 to 15% less does the trick. For example, for your 20 Mbps, you might try shaping at 17 to 18 Mbps.
05-01-2014 06:34 AM
Disclaimer
Posting
Nope.
Semi-true.
class preferred
class trans-apps
class general
class class-default
class realtime
priority 512
class class-default
05-01-2014 07:38 AM
Hi Joseph,
Thanks for the great explanation/clarification. Is it the value of the "shape average" that needs to be changed to "account for L2 overhead"?
Mike
05-01-2014 10:09 AM
Disclaimer
Posting
05-01-2014 10:49 AM
Thanks again, and best regards!
Mike
