02-16-2014 09:28 PM - edited 03-04-2019 10:21 PM
i have vpn connectivity between headoffice and branch office.At branch i have 2 mpbs CIR link.On which i want to
1Mbps reserved for VPN only.how i do the policy based traffic shapping.
Please help me out how i do this. below is my router configuration..
Current configuration : 2211 bytes
version 12.4
hostname rtttt_RTR
boot-start-marker
boot-end-marker
logging message-counter syslog
no logging console
enable password ********************************
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip domain lookup
ip name-server 202.143.124.1
ip name-server 8.8.8.8
no ipv6 cef
voice-card 0
archive
log config
hidekeys
crypto isakmp policy 10
hash md5
authentication pre-share
group 2
crypto isakmp key *********************** address 125.119.46.242
crypto ipsec transform-set tset esp-des esp-md5-hmac
crypto map smap 10 ipsec-isakmp
set peer 124.109.46.242
set transform-set tset
match address 101
interface FastEthernet0/0
ip address 203.143.128.154 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
crypto map smap
interface FastEthernet0/1
ip address 192.168.1.254 255.255.255.0
ip nat inside
duplex auto
speed auto
interface ATM0/2/0
no ip address
shutdown
no atm ilmi-keepalive
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 202.143.126.154
ip http server
no ip http secure-server
ip nat inside source list 111 interface FastEthernet0/0 overload
access-list 101 permit ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 192.168.101.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 111 deny ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 111 deny ip 192.168.1.0 0.0.0.255 192.168.101.0 0.0.0.255
access-list 111 deny ip 192.168.1.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 111 deny ip 192.168.1.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 111 permit ip 192.168.1.0 0.0.0.255 any
route-map nat permit 10
match ip address 111
control-plane
mgcp fax t38 ecm
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
02-17-2014 03:44 AM
Hello
Basic TS
policy-map Shape
class class-default
shape average 1024000
service-policy output Shape
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
02-17-2014 04:04 AM
I apply the following QOS setting.
VPN ACL is 101
NAT ACL is 111
(config)#class-map VPN
RTR(config-cmap)#match access-group 101
RTR(config)#class-map NAT
RTR(config-cmap)#match access-group 111
RTR(config-cmap)#exit
RTR(config)#policy-map multiple_classes
RTR(config-pmap)#class VPN
RTR(config-pmap-c)#shape average 800000
RTR(config-pmap-c)#exit
RTR(config-pmap)#class NAT
RTR(config-pmap-c)#shape average 1200000
RTR(config)#interface f
RTR(config)#interface fastEthernet 0/0
RTR(config-if)#service-policy output multiple_classes
but when i show its output i things its not applying on VPN traffic you can see the policy map with name of VPN its matchs is zero.Please help me out
#sh policy-map interface fastEthernet 0/0
FastEthernet0/0
Service-policy output: multiple_classes
Class-map: VPN (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group 101
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
queue limit 64 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 0/0
shape (average) cir 800000, bc 3200, be 3200
target shape rate 800000
Class-map: NAT (match-all)
92041 packets, 6969911 bytes
Match: access-group 111
Queueing
(queue depth/total drops/no-buffer drops) 0/5057/0
(pkts output/bytes output) 86983/6587913
shape (average) cir 1200000, bc 4800, be 4800
target shape rate 1200000
Class-map: class-default (match-any)
758316 packets, 186938379 bytes
5 minute offered rate 57000 bps, drop rate 0 bps
Match: any
(pkts output/bytes output) 758321/186940900
02-17-2014 04:57 AM
Hello
The reason for that is your acls are incorrect, Dont think qos is be able to look at its nattted address as an destination address from an ACL, hence the reason why you DO see a match on the acl111 but not on the 101.
Try creating new acls and specify certain host traffic from you lan that you want to shape
access-list 110 permit host 192,168.1.x
access-list 120 permit host 192,168.1.x
class-map VPN
match access-group 110
class-map NAT
match access-group 120
class VPN
bandwidth 400
class NAT
bandwidth 600
policy-map Default-Shape
class class-default
service-policy multiple_classes
service-policy output Default-Shape
res
Paul
Thanks.
02-17-2014 07:50 PM
Hi Paul,
thanks for help.
What i want to achive is that i want to reserve some of bandwith for VPN traffic and some for NAT.
I want that all host at branch use same bandwith.
Its much difffuclt to creat a sperate ACL for each host i have almost 50 plus employees at branch office.
