Community Helping Community
2506
Beginner
Traffic shaping / policing inbound traffic
I have a host with a 20mb mpls connection, with several remotes all with single T1 MPLS connections.
I have my interesting traffic being tagged with my desired DSCP values. (i can cofirm this with show policy-map int ...) Currently I'm only tagging my citrix traffic EF, AF41, AF42, 21, my management (ssh, telnet, tftp,) into 21 and allowing most everything else to fall into the default-class
The issue I am running into is from a remote site, if i download a file from my host it completely saturates my T1 and my traffic tagged EF or AF41 and AF42 suffers. My file transfer is being tagged as default-class. If i send the file out to my host, the shaping works as expected and my higher priority traffic isn't affected.
Most of the examples i've found are for two locaitons with the same speed, and traffic shaping seems like it would work much easier, but because my host has so much more bandwidth, it never even slows down. Is policing the correct thing to do at each remote, give my default class a very low CIR, but allow  BE to the full T1 bandwidth? Or is there something more graceful since this is a private MPLS connection
Thanks for the help!
Everyone's tags (6)
1 ACCEPTED SOLUTION
VIP Advisor
Re: Traffic shaping / policing inbound traffic
Sounds like you also need to apply some egress shaping/policing from the host towards the spokes.
I have attached a  good example from Ask the expert.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
kind regards
Paul
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future
2 REPLIES 2
VIP Advisor
res
Paul
Thanks.
kind regards
Paul
Beginner
Creating a class-map for each location was the only other thing i could think of, i was just hoping there was a more elegant solution. Thanks for the example as well!
Content for Community-Ad
FusionCharts will render here
