Traffice Flow
Hi All ,
I am working in global project.
I want to know the Traffice flow from site to site , from Site to Data center .
How can i check, I want to make a topology form site to site and site to data center.
Hi @Rajvendra pratap singh
  There are some ways to achieve that. It will depend on the budget.  Starting with a lower cost:
-  SNMP with open source monitoring tool like PRTG, Naggios or Zabbix.  Zabbix allow you to draw topologies and can show you the traffic per interface.
-Syslog with syslog server on linux machine and Grafana to show the data in dashboard.
- Netflow - You can activate netflow on the devices, configure exporters and use PRTG to generate the graphics
If you have a few truck of money
Cisco ThousandYes.
 This is an example of what you get
https://netcraftsmen.com/cisco-thousandeyes/
Dynatrace
https://www.dynatrace.com/monitoring/solutions/application-monitoring/?utm_source=google&utm_medium=cpc&utm_term=monitoring%20applications&utm_campaign=br-apm-application-performance-management&utm_content=none&utm_campaign_id=674205837&gclsrc=aw.ds&...
Cisco ThousandYes.
Dynatrace
