trafic on vlan
stephtchoko
Level 3
Level 3
please how to see trafic on a vlan.when i try show interface vlan i can't see trafic.
3550-Dla#show int vlan 11
Vlan11 is up, line protocol is up
Hardware is EtherSVI, address is 0012.43d4.bf80 (bia 0012.43d4.bf80)
Internet address is 192.168.1.1/30
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:09:07, output 00:00:24, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 315
Queueing strategy: fifo
Output queue: 0/40 (size/max)
228052 packets input, 16883793 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicast)
250875 packets output, 16883860 bytes, 0 underruns
0 output errors, 0 interface resets
3550-Dla#
Please need a help.
Amphitryon
If you really want a visual into your network, set up a SPAN and use a network analyzer...there are a few free ones out there for Windows, OmniPeek Personal and Wireshark etc...tcpdump.
Note; switches generally don't foward VLAN tags on a SPAN setup, you'd have to set up a tap to capture frames with tags -and ensure your network card driver does not strip the tags, many do.
-E
