85
Transparent Bridge between 2 serial interfaces on same ASR (Bridge-group command deprecated)
I have a requirement to test a system through an ASR 100X to a RS-530 Serial connected modem in loopback.
The key components are:
Anrirsu Tester (DCE) <--------> ASR <----------> Modem(Baseband in loopback)
The ASR is a single device with two connected serial interfaces, one to the tester (S0/1/0) and the other to the modem (S0/1/1), what I essentially need to do is create a transparent bridge between two interfaces on the same device.
This used to be easy on ISR running a standard IOS using 'Bridge Group #' commands, however  this command has been deprecated, I have looked into BDI but this would appear to be Ethernet only, there must be some way to achieve this.
The reason for needing this is to test end to end comms on a Satcom site through the router at 8Mbps (RS-530) to carry our BER tests (BERT) over extended serial cable distances up to and including 11 metres.
Cheers
Steve
Any assistance is gratefully received, if any more information is required, please let me know.
Everyone's tags (1)
Content for Community-Ad
August's Community Spotlight Awards
