Tried everything, but still high CPU utilisation on 2811 router
WalterKlomp
Hi Experts,
I have read an tried just about everything regarding CPU utilisation... I can't for the life of me figure out why the interrupt driven CPU usage is so high.
At around 6Mbps of VoIP traffic, the router is 100% CPU and it start dropping packets all over the place.
there is no logging in the access-list (there is only one inbound access list).
Using QoS or not, doesn't seem to make a difference
All route-caching features are ON. (CEF, Flow, Policy, Fast)
Yet the minimum CPU utilisation I have seen is 25%/25%... On average it's 40% during the day, but once traffic picks up to around 6000 packets per second, the router is gone...
I have a 50/50 Mbps connection, but I can use only 6 for VoIP ?
I hope somebody can help me.
Walter.
Show interfaces:
GigabitEthernet0/0 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 0014.1c26.7c30 (bia 0014.1c26.7c30)
  Description: $ETH-LAN$$FW_INSIDE$
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 6/255, rxload 7/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is T
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 11:55:29
  Input queue: 2/75/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: Class-based queueing
  Output queue: 0/100/64/0 (size/max total/threshold/drops)
     Conversations  0/2/256 (active/max active/max total)
     Reserved Conversations 4/4 (allocated/max allocated)
     Available Bandwidth 4000 kilobits/sec
  5 minute input rate 2793000 bits/sec, 3488 packets/sec
  5 minute output rate 2734000 bits/sec, 3632 packets/sec
     116982865 packets input, 3127961458 bytes, 0 no buffer
     Received 80940 broadcasts, 0 runts, 0 giants, 0 throttles
     776 input errors, 0 CRC, 0 frame, 0 overrun, 776 ignored
     0 watchdog, 0 multicast, 0 pause input
     122381088 packets output, 2917881813 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 lost carrier, 0 no carrier, 955 pause output
GigabitEthernet0/1 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 0014.1c26.7c31 (bia 0014.1c26.7c31)
  Description: $FW_OUTSIDE$
  MTU 1500 bytes, BW 50000 Kbit, DLY 100 usec,
     reliability 255/255, txload 12/255, rxload 12/255
  Last input 00:00:08, output 00:00:00, output hang never
  Last clearing of "show interface" counters 11:55:35
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Available Bandwidth 2000 kilobits/sec
  5 minute input rate 2382000 bits/sec, 3384 packets/sec
  5 minute output rate 2422000 bits/sec, 3233 packets/sec
     112019602 packets input, 1309720228 bytes, 0 no buffer
     Received 37 broadcasts, 0 runts, 0 giants, 0 throttles
     6 input errors, 0 CRC, 0 frame, 0 overrun, 6 ignored
     106502288 packets output, 1491121361 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 8 pause output
Show interface switching:
GigabitEthernet0/0 $ETH-LAN$$FW_INSIDE$
          Throttle count          6
                   Drops         RP          8         SP          0
             SPD Flushes       Fast          0        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs    2571886      Drops          0
    Protocol  IP
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
                 Process    2466474  232989228     834642  682286322
            Cache misses          0          -          -          -
                    Fast 1605087272   84348648 1819463644 4147073402
               Auton/SSE          0          0          0          0
    Protocol  DEC MOP
                 Process          0          0       2826     217602
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process    2568233  154045020     443185   26591100
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process     113630   41256882     170349   10220940
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    NOTE: all counts are cumulative and reset only after a reload.
GigabitEthernet0/1 $FW_OUTSIDE$
          Throttle count          3
                   Drops         RP         15         SP          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs       9773      Drops          0
    Protocol  IP
                 Process    1779287 1333404015     349499   37612434
            Cache misses        172          -          -          -
                    Fast 1319796001 2010536801 1103515986  380354212
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process       1420      85200       1422      85320
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process          0          0     170351   10221060
                    Fast          0          0         10       1100
               Auton/SSE          0          0          0          0
Show proc cpu sort looks like this at the moment:
CPU utilization for five seconds: 42%/41%; one minute: 41%; five minutes: 39%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
200     1147508     28799      39845  0.31%  0.03%  0.00%   0 Per-minute Jobs
  36      793656   1702120        466  0.07%  0.01%  0.00%   0 Per-Second Jobs
   2        9600    340675         28  0.00%  0.00%  0.00%   0 Load Meter
   3         832     19243         43  0.00%  0.00%  0.00%   0 CRYPTO IKMP IPC
   5           0         1          0  0.00%  0.00%  0.00%   0 EDDRI_MAIN
   7      592608     35982      16469  0.00%  0.00%  0.00%   0 Pool Manager
   6     2564412    211190      12142  0.00%  0.04%  0.05%   0 Check heaps
   9           0         1          0  0.00%  0.00%  0.00%   0 OIR Handler
   8           0         2          0  0.00%  0.00%  0.00%   0 Timers
  11       10240     56780        180  0.00%  0.00%  0.00%   0 Environmental mo
  12         120     28391          4  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  13           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  10           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  15       22864   1702016         13  0.00%  0.00%  0.00%   0 IPC Deferred Por
  16           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  17           0         1          0  0.00%  0.00%  0.00%   0 IPC BackPressure
  18      915940   2486783        368  0.00%  0.02%  0.00%   0 ARP Input
   1         164       113       1451  0.00%  0.00%  0.00%   0 Chunk Manager
  20           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  21           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  22           0         2          0  0.00%  0.00%  0.00%   0 DDR Timers
  23           0         2          0  0.00%  0.00%  0.00%   0 Entity MIB API
  24        4944    340578         14  0.00%  0.00%  0.00%   0 HC Counter Timer
  25           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  14       23928   1702015         14  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  19           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  28       24552   1702012         14  0.00%  0.00%  0.00%   0 GraphIt
  29           0         2          0  0.00%  0.00%  0.00%   0 Dialer event
  30           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  31           0         2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  32           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  33       27940    274500        101  0.00%  0.00%  0.00%   0 Net Background
  34        2680     54419         49  0.00%  0.00%  0.00%   0 Logger
  35       55040   1702009         32  0.00%  0.00%  0.00%   0 TTY Background
  26           4         1       4000  0.00%  0.00%  0.00%   0 MPLS HC Counter
  37        4444       498       8923  0.00%  0.00%  0.00% 322 Virtual Exec
  38           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  39           0         1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  40           0         1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  41           0         1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  42           0         1          0  0.00%  0.00%  0.00%   0 sal_dpc_process
  43           0         1          0  0.00%  0.00%  0.00%   0 ARL Table Manage
  44           0         2          0  0.00%  0.00%  0.00%   0 ESWPPM
  45           0         2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  46           0         2          0  0.00%  0.00%  0.00%   0 ESWILPPM
  47           0         2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  48       38084   6754866          5  0.00%  0.00%  0.00%   0 Netclock Backgro
  49           0         2          0  0.00%  0.00%  0.00%   0 SM Monitor
  27           0         2          0  0.00%  0.00%  0.00%   0 SMART
  51           0         2          0  0.00%  0.00%  0.00%   0 VNM DSPRM MAIN
  52           0         1          0  0.00%  0.00%  0.00%   0 DSPFARM DSP READ
  50        1884    283828          6  0.00%  0.00%  0.00%   0 mxt5100
  54           0         1          0  0.00%  0.00%  0.00%   0 HDV background
  55           0         2          0  0.00%  0.00%  0.00%   0 Multi-ISA Event
  56           0         1          0  0.00%  0.00%  0.00%   0 Multi-ISA Cleanu
  57           0         1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
  58           0         1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Re
  59         188     56780          3  0.00%  0.00%  0.00%   0 Call Management
  60           0         1          0  0.00%  0.00%  0.00%   0 AAL2CPS TIMER_CU
  61           0         1          0  0.00%  0.00%  0.00%   0 CES Line Conditi
  62       10536   1702018          6  0.00%  0.00%  0.00%   0 Crypto Device Up
  64           0         2          0  0.00%  0.00%  0.00%   0 dot1x
  65           0         2          0  0.00%  0.00%  0.00%   0 DTP Protocol
  66       13908   1702012          8  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
  67         516    170320          3  0.00%  0.00%  0.00%   0 EtherChnl
  68           0         1          0  0.00%  0.00%  0.00%   0 L2X Data Daemon
  69           0         2          0  0.00%  0.00%  0.00%   0 Dot11 auth Dot1x
  70           0         1          0  0.00%  0.00%  0.00%   0 Dot11 Mac Auth
  71           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  72           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  73          20       161        124  0.00%  0.00%  0.00%   0 AAA Server
  74           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  75           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  76           0         1          0  0.00%  0.00%  0.00%   0 AC Mgr
  78        3920     27218        144  0.00%  0.00%  0.00%   0 EM FD Syslog
  79           0         2          0  0.00%  0.00%  0.00%   0 EM FD SNMP
  80           0         2          0  0.00%  0.00%  0.00%   0 EM FD Memory Thr
  81           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM Input
  82           0         2          0  0.00%  0.00%  0.00%   0 ATM OAM TIMER
  83     1952492   2153707        906  0.00%  0.00%  0.00%   0 IP Input
  84           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  85           0        52          0  0.00%  0.00%  0.00%   0 TurboACL
  87           0         3          0  0.00%  0.00%  0.00%   0 PPP Hooks
  88           0         1          0  0.00%  0.00%  0.00%   0 SSS Manager
  89        1164    227099          5  0.00%  0.00%  0.00%   0 SSS Test Client
  90           0         1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
  91       32544   6653217          4  0.00%  0.00%  0.00%   0 SSS Feature Time
  92           0         1          0  0.00%  0.00%  0.00%   0 VPDN call manage
  93           0         1          0  0.00%  0.00%  0.00%   0 L2X Socket proce
  94           0         1          0  0.00%  0.00%  0.00%   0 L2X SSS manager
  95           0         2          0  0.00%  0.00%  0.00%   0 L2TP mgmt daemon
  96           0         1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
  97           0         2          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
  98           0         2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
  99       14268     55166        258  0.00%  0.00%  0.00%   0 IP Background
100        3140     28401        110  0.00%  0.00%  0.00%   0 IP RIB Update
  53           0         2          0  0.00%  0.00%  0.00%   0 FLEX DNLD MAIN
102           0         2          0  0.00%  0.00%  0.00%   0 PPP IPCP
103           0         1          0  0.00%  0.00%  0.00%   0 Socket Timers
104         952     14945         63  0.00%  0.00%  0.00%   0 TCP Timer
105          88        62       1419  0.00%  0.00%  0.00%   0 TCP Protocols
106           0         1          0  0.00%  0.00%  0.00%   0 COPS
107      385868   2177778        177  0.00%  0.00%  0.00%   0 CEF process
101           0         2          0  0.00%  0.00%  0.00%   0 PPP IP Route
109           0         1          0  0.00%  0.00%  0.00%   0 MRD
110           0         1          0  0.00%  0.00%  0.00%   0 IGMPSN
111           0         2          0  0.00%  0.00%  0.00%   0 RLM groups Proce
112           0         2          0  0.00%  0.00%  0.00%   0 DDP
113           0         2          0  0.00%  0.00%  0.00%   0 SNMP Timers
114           4         2       2000  0.00%  0.00%  0.00%   0 SCTP Main Proces
115           0         1          0  0.00%  0.00%  0.00%   0 IUA Main Process
116       44956   1702018         26  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
117           0         1          0  0.00%  0.00%  0.00%   0 bsm_timers
118       12636   1702017          7  0.00%  0.00%  0.00%   0 bsm_xmt_proc
119           0         1          0  0.00%  0.00%  0.00%   0 CES Client SVC R
120       24920   3328139          7  0.00%  0.00%  0.00%   0 IP NAT Ager
121           0         2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
122        9864     28373        347  0.00%  0.00%  0.00%   0 IP Cache Ager
123        4308     28393        151  0.00%  0.00%  0.00%   0 Adj Manager
124       30476     56338        540  0.00%  0.00%  0.00%   0 HTTP CORE
125           0        33          0  0.00%  0.00%  0.00%   0 RARP Input
126           0         1          0  0.00%  0.00%  0.00%   0 PAD InCall
127           0         2          0  0.00%  0.00%  0.00%   0 X.25 Background
128           0         2          0  0.00%  0.00%  0.00%   0 PPP Bind
129           0         2          0  0.00%  0.00%  0.00%   0 PPP SSS
130       67080  17006612          3  0.00%  0.00%  0.00%   0 RBSCP Background
131           0         2          0  0.00%  0.00%  0.00%   0 Tag Input
132        2488    340578          7  0.00%  0.00%  0.00%   0 L2F management d
133           4         1       4000  0.00%  0.00%  0.00%   0 PPTP Mgmt
134           0         2          0  0.00%  0.00%  0.00%   0 PPTP Data
135           0         1          0  0.00%  0.00%  0.00%   0 Inspect Timer
136           0         1          0  0.00%  0.00%  0.00%   0 Onboard VPN Comm
137          36      5679          6  0.00%  0.00%  0.00%   0 Authentication P
138           0         1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
139           0         1          0  0.00%  0.00%  0.00%   0 IPS Timer
140           0         2          0  0.00%  0.00%  0.00%   0 SDEE Management
141           0         1          0  0.00%  0.00%  0.00%   0 IPv6 Inspect Tim
142           0         2          0  0.00%  0.00%  0.00%   0 URL filter proc
143           0         3          0  0.00%  0.00%  0.00%   0 Crypto HW Proc
144         632     68141          9  0.00%  0.00%  0.00%   0 CRM_CALL_UPDATE_
145          96         2      48000  0.00%  0.00%  0.00%   0 CCVPM_HDSPRM
146        5600    630378          8  0.00%  0.00%  0.00%   0 FLEX DSPRM MAIN
147        2368    630376          3  0.00%  0.00%  0.00%   0 FLEX DSP KEEPALI
148           0         4          0  0.00%  0.00%  0.00%   0 HDA DSPRM MAIN
149           0         3          0  0.00%  0.00%  0.00%   0 Crypto WUI
150           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
151           0         1          0  0.00%  0.00%  0.00%   0 EM Background Pr
152           0         1          0  0.00%  0.00%  0.00%   0 Key chain liveke
153           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
154         684      2618        261  0.00%  0.00%  0.00%   0 LOCAL AAA
156           0         2          0  0.00%  0.00%  0.00%   0 TPLUS
157           0         2          0  0.00%  0.00%  0.00%   0 VSP_MGR
158           0         1          0  0.00%  0.00%  0.00%   0 encrypt proc
159      790096     69403      11384  0.00%  0.00%  0.00%   0 Crypto Support
160           4         1       4000  0.00%  0.00%  0.00%   0 CCVPM_HTSP
161           0         2          0  0.00%  0.00%  0.00%   0 VPM_MWI_BACKGROU
162           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_R2
163          20      1893         10  0.00%  0.00%  0.00%   0 FB/KS Log HouseK
164           0         1          0  0.00%  0.00%  0.00%   0 CCSWVOICE
166           0         1          0  0.00%  0.00%  0.00%   0 http client proc
167           0         1          0  0.00%  0.00%  0.00%   0 QOS_MODULE_MAIN
168           0         1          0  0.00%  0.00%  0.00%   0 RPMS_PROC_MAIN
169           0         1          0  0.00%  0.00%  0.00%   0 VoIP AAA
170         392      3989         98  0.00%  0.00%  0.00%   0 crypto engine pr
171          40         4      10000  0.00%  0.00%  0.00%   0 Crypto CA
172           0         1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
173           0         1          0  0.00%  0.00%  0.00%   0 Crypto SSL
174         300      1644        182  0.00%  0.00%  0.00%   0 Crypto ACL
175           0         1          0  0.00%  0.00%  0.00%   0 CRYPTO QoS proce
176      666252    118143       5639  0.00%  0.00%  0.00%   0 Crypto IKMP
177        4388     96314         45  0.00%  0.00%  0.00%   0 IPSEC key engine
178           0         1          0  0.00%  0.00%  0.00%   0 IPSEC manual key
179           8         8       1000  0.00%  0.00%  0.00%   0 Crypto PAS Proc
180         536      5782         92  0.00%  0.00%  0.00%   0 Crypto Delete Ma
181           0         2          0  0.00%  0.00%  0.00%   0 Key Proc
182           0         1          0  0.00%  0.00%  0.00%   0 PM Callback
183      370072      1186     312033  0.00%  0.00%  0.00%   0 crypto sw pk pro
184           0         1          0  0.00%  0.00%  0.00%   0 DATA Transfer Pr
185           0         1          0  0.00%  0.00%  0.00%   0 DATA Collector
186          32        78        410  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
187           0         5          0  0.00%  0.00%  0.00%   0 EM Server
188         480    170320          2  0.00%  0.00%  0.00%   0 RMON Recycle Pro
189           0         2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
190           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
191         128      2136         59  0.00%  0.00%  0.00%   0 IpSecMibTopN
192           4         2       2000  0.00%  0.00%  0.00%   0 VLAN Manager
193       19784   1701591         11  0.00%  0.00%  0.00%   0 trunk conditioni
194           0         1          0  0.00%  0.00%  0.00%   0 trunk conditioni
195           0         2          0  0.00%  0.00%  0.00%   0 EM Applet Direct
196           0         1          0  0.00%  0.00%  0.00%   0 VPDN Scal
198        9696    113592         85  0.00%  0.00%  0.00%   0 Net Input
199       13112    340580         38  0.00%  0.00%  0.00%   0 Compute load avg
108           0         2          0  0.00%  0.00%  0.00%   0 L2MM
201           0         1          0  0.00%  0.00%  0.00%   0 TCP Driver
202           0         1          0  0.00%  0.00%  0.00%   0 TCP Listener
203        2064     59056         34  0.00%  0.00%  0.00%   0 CEF Scanner
204         152       949        160  0.00%  0.00%  0.00%   0 SSH Event handle
205           0         1          0  0.00%  0.00%  0.00%   0 IP NAT WLAN
206        4428     66710         66  0.00%  0.00%  0.00%   0 IP VFR proc
207           0         2          0  0.00%  0.00%  0.00%   0 IP Flow Backgrou
208       28196     83210        338  0.00%  0.00%  0.00%   0 IP SNMP
209        8356     42033        198  0.00%  0.00%  0.00%   0 PDU DISPATCHER
210       33096     42036        787  0.00%  0.00%  0.00%   0 SNMP ENGINE
211           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
212           0         1          0  0.00%  0.00%  0.00%   0 SNMP Traps
213       26192    307846         85  0.00%  0.00%  0.00%   0 NAT MIB Helper
214       25572   1730027         14  0.00%  0.00%  0.00%   0 NTP
17 Replies 17
do u have a 2811 or 2821?? because one of your posts you posted the cpu on a 2821 and also your sh ver shows the same???...leo seems to have hinted you to the right thing
Kishore
Sorry it's a 2821 ...
If I disable virtual-reassembly then people seem to have trouble uploading big queries to my sql servers... (which i find a bit strange)
sameershrestha
Hi All,
I also have the same problem with 2811.
Is there any particular IOS that fixes this issue. Below is my output for ver and processes
Cisco IOS Software, 2800 Software (C2800NM-IPBASEK9-M), Version 12.4(24)T4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 03-Sep-10 05:39 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
ipscape-myob uptime is 6 weeks, 5 days, 17 hours, 18 minutes
System returned to ROM by reload at 10:33:59 UTC Thu Apr 10 2014
System image file is "flash:c2800nm-ipbasek9-mz.124-24.T4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 514048K/10240K bytes of memory.
Processor board ID FHK1238F1D4
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
CPU utilization for five seconds: 90%/77%; one minute: 79%; five minutes: 76%
   8    20693808    28614857        723  7.67%  1.24%  0.44%   0 IP SLAs Respond                                e
  91    13460456    18459988        729  3.27%  0.67%  0.31%   0 IP Input
 143     3167640  1026953957          3  1.19%  1.62%  1.68%   0 HQF Shaper Back                                g
 184      809676   128826693          6  0.39%  0.38%  0.39%   0 PPP manager
 196        1072         112       9571  0.31%  0.23%  0.06% 514 Virtual Exec
 185      771340   128826711          5  0.23%  0.18%  0.16%   0 PPP Events
Any help would be muchly appreciated.
Thank You!
