trunk/subinterfaces not working
bgoulet00
Level 2
Level 2
i've configured this easily on a cat9300 connected to an isr1000 but i'm having issues getting it to work between a 2960cx and isr1841.  i can ping across the native vlan but not any of the others.  i'm not sure if the old 1841 needs some extra stuff setup that we take for granted in the new platforms? the 1841 is running 12.4(17)
SWITCH CONFIG
interface GigabitEthernet0/2
switchport trunk native vlan 62
switchport mode trunk
end
Vlan5 10.89.5.130 YES NVRAM up up
Vlan62 10.89.62.244 YES DHCP up up
ROUTER CONFIG
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.5
encapsulation dot1Q 5
ip address 10.89.5.129 255.255.255.192
interface FastEthernet0/0.62
encapsulation dot1Q 62 native
ip address 10.89.62.1 255.255.255.0
ip helper-address 10.224.109.35
ip helper-address 10.224.209.25
21 Replies 21
Thanks for the show interface outputs. This is quite puzzling. Am I understanding correctly that if you make vlan 5 the native vlan that it works  but vlan 62 stops working. And while vlan 62 is native vlan that vlan 5 does not work?
The posted configs seem appropriate. The output of various show commands indicate that both devices treat the connection as a dot1q trunked interface with 2 vlans. And both devices see the connection as up and active. But only the native vlan works. This suggests that there is some issue about vlan tagging.
I am thinking more and more about the unknown protocol drops
461621 unknown protocol drops
And increasingly I am thinking that these are related to whatever the problem is about tagging the traffic.
At this point I am grasping at straws and have these suggestions:
- is there any possibility of opening a case with Cisco TAC about this? (I suspect that with equipment as old as this the answer is no, but need to ask the question)
- I wonder about the possibility of a bug in the software of one of the devices. Is there any chance of running a different version of code on either (or both) of the devices?
- if you save the configs and reboot both devices does the behavior change?
- if there any possibility of doing a packet capture on this traffic?
Rick
i'd love nothing more than to upgrade the IOS but the router is so old cisco no longer posts the images for it.  also because of the age we have no support for it.  i did just upgrade the switch to the current cisco recommended version and it didn't make a difference.
i have rebooted both devices with no change.  i don't have any way to packet capture.  i did run an ip packet debug and got this:
018404: Oct 9 17:19:03.778: IP: s=10.89.5.130 (local), d=10.89.5.129 (Vlan5), len 100, encapsulation failed
Oct 9 17:37:30.125: IP: s=10.89.5.129 (local), d=10.89.5.130 (FastEthernet0/0.5), len 100, encapsulation failed
when i googled the error i found another post from you saying that the layer2 encapsulation can fail if arp failes, which it is.
Glad that you found that post explaining that attempting to send an IP packet when there is no arp entry for the next hop mac address will result in encapsulation failure. So the question becomes why is arp failing?
The show commands from both devices indicate that both devices see it as dot1q encapsulation. But the fact that it seems that no traffic actually goes through the tagged vlan makes me wonder if one of the devices is really having problems with it. I wonder if we might get any insight if you do this on both devices:
- make sure that the logging level is set to debug
- show cdp neighbor detail
- shut the interface
- no shut the interface
- attempt to ping the neighbor address
- post any output
Rick
hahaha!  OMG!  i figured it out.   the site has an unmanage dumb switch in the path between the ISR and 2960 so dot1q tags no worky.  seeing no entry in the switch logs after the shut/noshut on the router side was the give-away.  no one on IT staff has ever visited this site and we got no real documentation from the company we acquired it from.  thanks for all your help.
WOW ! That is a surprise. But it sure does explain the symptoms you were experiencing. A well deserved +5 for good troubleshooting on this.
Rick
balaji.bandi
Seen it before - also complain to the community forum - the user is an unrelated topic and no relation to the post reply. - have posted our group.
BB
Hi friend,
ISR-SW
in-between there is trunk
so can you clarify what issue which one is not pingable?
