267
Beginner
Trying to connect home lab to ISP through home router
Hi all,
Currently studying for my ICND1 (it's actually tomorrow) and have a pretty decent running home lab.
I have set up a few vlans spanning three switches with a ROAS.  I'm looking to use a second 1841 ISR as an edge router between my home lab and my personal network running off an Apple Airport Extreme.
The two biggest issues I'm facing are the inability to ping the outbound interface of the edge router and secondly how to configure said interface.
I am able to ping all R1 interfaces from any host, but have no connectivity to R2 and therefore the internet.
My thought process is to have ROAS for the vlan switching and management and use the other router for NAT purposes, I'm still learning so please go easy on me.
Below are the running configs:
R1#sh run
Building configuration...
Current configuration : 2664 bytes
! Last configuration change at 17:19:56 UTC Sun Mar 3 2019
version 15.1
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip dhcp smart-relay
ip dhcp excluded-address 192.168.0.1
ip dhcp excluded-address 192.168.0.0
ip dhcp excluded-address 192.168.0.2
ip dhcp excluded-address 192.168.1.0
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.2
ip dhcp excluded-address 192.168.2.0
ip dhcp excluded-address 192.168.2.1
ip dhcp excluded-address 192.168.2.2
ip dhcp excluded-address 192.168.3.0
ip dhcp excluded-address 192.168.3.1
ip dhcp excluded-address 192.168.3.2
ip dhcp pool VLAN101
network 192.168.1.0 255.255.255.0
default-router 192.168.1.2
dns-server 8.8.8.8
ip dhcp pool VLAN102
network 192.168.2.0 255.255.255.0
default-router 192.168.2.2
dns-server 8.8.8.8
ip dhcp pool VLAN103
network 192.168.3.0 255.255.255.0
default-router 192.168.3.2
dns-server 8.8.8.8
ip cef
no ipv6 cef
license udi pid CISCO1841 sn FTX0951Z126
redundancy
interface FastEthernet0/0
ip address 192.168.100.100 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.0.2 255.255.255.0
ip helper-address 192.168.100.100
interface FastEthernet0/0.100
interface FastEthernet0/0.101
encapsulation dot1Q 101
ip address 192.168.1.2 255.255.255.0
interface FastEthernet0/0.102
encapsulation dot1Q 102
ip address 192.168.2.2 255.255.255.0
interface FastEthernet0/0.103
encapsulation dot1Q 103
ip address 192.168.3.2 255.255.255.0
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface Serial0/0/0
ip address 192.168.101.100 255.255.255.0
no fair-queue
clock rate 128000
interface Serial0/0/1
no ip address
shutdown
clock rate 125000
interface Serial0/1/0
no ip address
shutdown
router rip
version 2
network 192.168.0.0
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
ip route 0.0.0.0 0.0.0.0 192.168.101.101
ip route 192.168.0.0 255.255.0.0 Serial0/0/0
logging esm config
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
R2#sh run
Current configuration : 1518 bytes
! Last configuration change at 18:15:50 UTC Sun Mar 3 2019
version 15.1
service password-encryption
hostname R2
boot-start-marker
boot-end-marker
enable secret 5 $1$tJVL$gmhxR78bNQysJmSDTtJJS.
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
license udi pid CISCO1841 sn FTX1005Y23V
redundancy
no ip address
shutdown
duplex auto
speed auto
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
ip address 192.168.101.101 255.255.255.0
ip nat inside
no fair-queue
no ip address
shutdown
clock rate 125000
no ip address
shutdown
router rip
version 2
network 10.0.0.0
network 192.168.0.0
no auto-summary
no ip http server
ip nat inside source list NAT_ADDRESSES interface FastEthernet0/1 overload
ip route 192.168.0.0 255.255.0.0 10.0.1.200
ip access-list standard NAT_ADDRESSES
permit 192.168.0.0 0.0.255.255
logging esm config
control-plane
line con 0
password 7 094F471A1A0A
logging synchronous
line aux 0
line vty 0 4
login
transport input all
end
_____________________________________________________________________________
S3#sh run
Current configuration : 5533 bytes
version 12.2
no service pad
hostname S3
boot-start-marker
boot-end-marker
enable secret 5 $1$OHZX$4j9XZbH631qM2Een/5rH21
no aaa new-model
system mtu routing 1500
vtp interface fa0/2
no ip domain-lookup
crypto pki trustpoint TP-self-signed-97243904
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-97243904
revocation-check none
rsakeypair TP-self-signed-97243904
crypto pki certificate chain TP-self-signed-97243904
certificate self-signed 01
[output cut]
spanning-tree mode pvst
vlan internal allocation policy ascending
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 103
interface FastEthernet0/4
interface FastEthernet0/5
[output cut]
interface FastEthernet0/48
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface Vlan1
ip address 192.168.0.1 255.255.255.0
interface Vlan101
description S1
interface Vlan102
description S2
ip address 192.168.2.1 255.255.255.0
interface Vlan103
description S3
ip address 192.168.3.1 255.255.255.0
ip classless
ip http server
vstack
banner motd ^UNAUTHORIZED USE PROHIBITED^
line con 0
password 7 060506324F41
login
line vty 0 4
login
line vty 5 15
login
5 REPLIES 5
Hall of Fame Guru
Re: Trying to connect home lab to ISP through home router
You have a default route on R1 pointing to 192.168.101.101 which is fine but on R2 you have a route for 192.168.0.0 255.255.0.0 pointing to 10.0.1.200.
What is 10.0.1.200 because R2 does not have an interface in that subnet ?
Also your RIP configuration, be aware that entering 192.168.0.0 does not include all the 192.168.x.x subnets because RIP is classful so that only covers 192.168.0.0/24 and not the other 192.168.x.0/24 subnets you have used on R1.
Jon
Beginner
Hi Jon,
10.0.1.200 puts R2 on my home network, just outside of the DHCP pool. My thought was to use that router simply to NAT from home network to my lab environment.
Thanks for the heads up on the RIP error!
-Sam
Hall of Fame Master
Here are things that I notice in your configs:
1) on R1 you have dhcp excluded addresses that include .0 such as
These addresses are the base address of the network and not host addresses and as such you do not need to exclude them. Excluding them does not create a problem. But they do not do any good and you should remove them.
2) you exclude addresses for 192.168.0.0. But I do not see any dhcp scope for 192.168.0.0.
3) You have 2 different interfaces which are trying to process for the native vlan
duplex auto
speed auto
The physical interface has an IP address and so it would process for untagged frames from the native vlan. But you also configure F0/0.1 for the native vlan and give it a different IP address. You should not have 2 different interfaces both trying to process the native vlan. Decide which one you want to really process the native vlan and remove the other.
4) You have several sub interfaces configured with ip helper-address
the helper address is used when the dhcp server is remote and the router needs to forward dhcp requests. But your router has the scopes and is acting as the dhcp server. So you do not need helper address on the router interfaces.
5) You configure this sub interface which suggests that it should have a vlan
but there is no encapsulation command. So there is no vlan on this sub interface. I am not sure what you intended here but either you need to correct it or you need to remove it.
I also note that the IP address configured here duplicates the address of the physical interface. IOS should not allow that.
6) Under router rip you have a single network statement
network 192.168.0.0
I am not sure if you were thinking of this as 192.168.0.0/16 (to include each of the private address subnets). But IOS will treat it as 192.168.0.0/24. That network might or might not exist depending on how your solve 3). You want rip to advertise the networks on your vlans. So you need to have a network statement for each vlan network. And you certainly want rip to run on the serial interface. So you need to have a network statement for that network.
7) You have 2 static default routes configured that do the same thing. I don't know why you have both. You should remove one of them.
8) You have a static route for 192.168.0.0
I am not clear where other networks in 192.168.0.0 are. But since this route sends them to the same place as the default route this route is not needed.
9) On R2 under router rip you have 2 network statements
network 10.0.0.0
network 192.168.0.0
I do not see a network 10.0.0.0 on this router. What is it supposed to be? If it is not real then remove it. My comment here about 192.168.0.0 is the same as 6) You need rip running at least on the serial interface and so need a network statement for that network.
10) you have this static route
My comment sort of relates to 8) asking where are these other networks supposed to be? And where is this next hop of 10.0.1.200?
11) On S3 I see multiple trunks and a few ports assigned to vlan 103. Are the vlans created correctly and are ports assigned to them?
12) You have 4 vlan interfaces configured on this switch. I am not sure why. It is not clear whether this switch is a layer 2 switch or a layer 3 switch. But I do not see ip routing enabled so it is certainly acting like a layer 2 switch. In which case it should have only a single vlan interface with an IP address.
Rick
Beginner
Hi Rick,
First off- thanks for taking the time to write an in depth reply, I really appreciate it.
I got rid of the subinterface running the native Vlan and the other useless subinterface, didn't think to assign the native vlan to the physical interface, but it makes perfect sense.
I have amended the RIP commands to cover all networks including the serial connection.
The 10.0.1.200 address was assigned to R2 with the idea that the router would preform NAT and link my lab to my home network. I'm using an Airport Extreme for my home connection and 10.0.1.200 is just outside of the DHCP scope on that router, but still on the network.
S3 is indeed a layer three switch, I was experimenting with using it as a VTP server.
After I made the recommended changes I'm able to ping local interface and default gateway, but am unable to ping R2 and thus the internet. My host states there is no DNS server when trying to access the internet.
Thanks again, as you can tell I'm pretty new to all of this.
Hall of Fame Master
Both Jon and I have asked about 10.0.1.200. In one response you say that
and in this most recent response you say that
How is that address assigned to R2? Is it possibly the address learned by DHCP on Fa0/1? If not then neither Jon nor I can see how R2 would know how to relate to that address.
You have made a lot of changes. Perhaps it would be helpful if you post a fresh copy of show run so that we can see what is current in the config. It would also be helpful if you would post the output of the commands show ip route and of show arp.
Rick
Content for Community-Ad
July's Community Spotlight Awards
