BVC
Beginner
Beginner
Tunnel Endpoint Discovery on Cisco ISR 4221
Is it possible to enable TED on a Cisco ISR 4221 running the universalk9 16.09.02 IOS?
Every time I try to put this command in  crypto map test_vpn 10 ipsec-isakmp dynamic test_map discover it gives me an error saying 'Tunnel endpoint discovery is not supported by the current hardware crypto engine'. Is there another way to configure TED on this IOS?
Any help will be much appreciated.
2 REPLIES 2
Georg Pauwen
VIP Master
I don't think TED is supported at all on the ISR4K. It is supported e.g. on the ASR920, which is more geared towards service providers...
Thanks for the response, do you know any other Cisco routers that support this feature or anywhere that I can go to find out.
