Tunnel is UP However Unable to route traffic thru a P2P IPSec tunnel
jherricke68
Beginner
Beginner
Hey guys,
I've setup a single P2P IPsec tunnel between two 880 series routers, the tunnel appears to be UP/IDLE from both ends, encryption looks fine however when I trace route an IP, seeing the route go thru the NAT overload out the the Internet. Thought I had this figured out, see my attached run-configs. Can anyone help point me in the right direction?
Thanks!
6 Replies 6
add the PFS group to your policies and crypto maps on BOTH sides:
Office_G1
crypto isakmp policy 1
hash md5
authentication pre-share
group 2
crypto isakmp key KEY address 65.175.135.XX
crypto map CMAP 10 ipsec-isakmp
set peer 65.175.135.XX
set transform-set TS
set pfs group2
match address 115
Office_A2
hash md5
group 2
crypto isakmp key KEY address 72.73.127.XXX
set peer 72.73.127.XXX
set pfs group2
match address 115
Thank you, but how does that fix my routing issue?
Without it, my encryption already working fine, just trying to understand why your suggesting i do this?
Thanks for helping.
JH
where do you originate the traceroute from, the router or a PC ? The pfs group setting was suggested because I had encountered an almost identical problem a while ago on the 880...
It might be worth while trying to use an SVTI instead of the crypto map. Do you know how to configure this ? Otherwise I'll send over the configs...
in the meantime, try to change the default routes so they point to the outgoing interface:
ip route 0.0.0.0 0.0.0.0 FastEthernet4
Trace route from a PC on the LAN side of router G1.
yes, please send me configs for using  SVTI. Never tried that before and might give it a shot.
Thanks!
here are the configs (changes and additions marked in bold). Basically, you create two tunnel interfaces and get rid of the crypto map. You then just route traffic that you want to be encrypted over the tunnel.
OFFICE_G1
version 15.3
hostname OFFICE_G1
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
aaa authentication login default line local
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
clock timezone EST -5 0
no ip source-route
ip cef
no ipv6 cef
ip ssh authentication-retries 5
ip ssh version 2
hash md5
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set TS esp-3des esp-md5-hmac
crypto ipsec profile IPSEC_PROFILE
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address 72.73.127.XXX 255.255.255.XXX
no ip redirects
no ip unreachables
ip mtu 1454
ip nat outside
ip virtual-reassembly in
ip tcp adjust-mss 1414
duplex auto
speed auto
no cdp enable
interface Tunnel 0
ip address 172.16.0.1 255.255.255.0
tunnel source 72.73.127.xx
tunnel destination 65.175.135.xx
tunnel mode ipsec ipv4
tunnel protection ipsec profile IPSEC_PROFILE
interface Vlan1
ip address 172.250.254.250 255.255.255.0
ip nat inside
ip tcp adjust-mss 1450
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 65.175.135.xx
ip route 172.250.1.0 255.255.255.0 Tunnel 0
access-list 23 permit any
access-list 1 permit 172.250.254.0 0.0.0.255
OFFICE_A2
Current configuration : 4035 bytes
version 15.0
no service pad
hostname OFFICE_A2
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
memory-size iomem 10
no ip subnet-zero
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 172.250.1.205
ip dhcp excluded-address 172.250.1.254
ip dhcp excluded-address 172.250.1.10
ip dhcp excluded-address 172.250.1.11
ip dhcp excluded-address 172.250.1.12
ip dhcp excluded-address 172.250.1.13
ip dhcp excluded-address 172.250.1.14
ip dhcp excluded-address 172.250.1.15
ip dhcp excluded-address 172.250.1.50
ip dhcp excluded-address 172.250.1.51
ip dhcp excluded-address 172.250.1.52
ip dhcp excluded-address 172.250.1.53
ip dhcp excluded-address 172.250.1.54
ip dhcp excluded-address 172.250.1.55
ip dhcp pool sdm-pool
import all
network 172.250.1.0 255.255.255.192
default-router 172.250.1.254
lease 0 2
ip cef
ip cef accounting per-prefix
no ip bootp server
ip inspect one-minute low 500
ip inspect one-minute high 600
ip inspect dns-timeout 10
ip inspect tcp idle-time 3650
ip inspect tcp max-incomplete host 49 block-time 19
ip inspect name watchdog1 tcp audit-trail on
no ipv6 cef
ip ssh version 2
hash md5
description INTERNET_INTERFACE
ip address 65.175.135.XX 255.255.255.0
no ip redirects
no ip unreachables
ip nat outside
ip inspect watchdog1 in
duplex auto
speed auto
no cdp enable
interface Tunnel 0
ip address 172.16.0.2 255.255.255.0
tunnel source 65.175.135.xx
tunnel destination 72.73.127.xx
interface Vlan1
description OFFICE_A2_LAN
ip address 172.250.1.254 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
hold-queue 32 in
no ip http server
ip dns server
ip route 0.0.0.0 0.0.0.0 72.73.127.xx
ip route 172.250.254.0 255.255.255.0 Tunnel 0
access-list 1 permit 172.250.1.0 0.0.0.255
