10-29-2015 01:53 PM - edited 03-05-2019 02:37 AM
So about a week ago, I had some trouble with my Cisco 5515 (yes it was user caused).
I got some great help on here and was able to get back up and running. But, now I need to clean up and fix things and try adding again the access groups I was trying to before
so, this is what fixed my situation
"no access-group global_access global"
So, what I would like to do is cleanup the access group rules and add the a couple
So, how do I turn on just the access rules I think I need?
The rule I want to add is I have a website inside my network and want to make it accessible to the outside world
outside ip address is 204.x.x.56
inside ip address is 10.10.15.0
This is the access rule I tried to create the messed everything up to begin with.
Solved! Go to Solution.
10-29-2015 04:21 PM
Chris
I believe the acl you had was fine it was just that you applied it as global acl and not an interface acl.
Personally I would rename the acl to outside_access_in as a more obvious name and then apply it to the outside interface so -
access-group outside_access_in in interface outside
that should do it.
Do you still have the acl or do you need it ?
Jon
11-10-2015 09:16 AM
If the port accessed on the outside is port 81 ie. you are not translating the port then yes but is it ie. the client on the outside would have to know that port number.
Are you sure it is that port number on the outside ?
In terms of the acl I don't write them like that.
I would just do -
access-list outside_access_in permit tcp any host 10.10.3.x eq 81
but then perhaps I am using the old way of doing things.
Also if the subnet is 10.10.3.0/24 then the client cannot be 10.10.3.0.
Jon
10-29-2015 04:21 PM
Chris
that should do it.
Jon
10-30-2015 01:04 PM
Jon,
My bad I meant to hit reply and missed.
I don't have the ACL or any of the information for this one. I deleted all the outstanding acl/nat/objects I created. Wanted to start fresh.
So, this is for an HTTP server
outside interface is TWTC
inside interface is NAS-Main
internal http server ip is 10.10.15.0
outside ip is 204.x.x.65
I thought a link I found solved that, but it apparently didn't
So, what do I do with this one? After this one I am going to work on the really ugly port forwarding issue that started the whole mess.
10-30-2015 01:12 PM
The simplest way -
access-list outside_access_in permit tcp any 10.10.15.x eq http
note you said inside IP was 10.10.15.0 but I suspect it isn't.
Then just apply the acl to the outside interface as in my previous post.
You can define object-groups for the ports and the server IP if you want, I was just giving you the quickest way.
Jon
11-10-2015 08:40 AM
ok they tossed a twist at me and I am trying to do this, here is what I got
the internal ip address is actually 10.10.3.0. So, they want it to respond to port 81
http://10.10.3.0:81/, the site comes up just fine on the internal side of the network.
This is what I created so far
object network Support-out
nat (inside,outside) static 216.54.x.52
object service Support-site service tcp source eq 81 destination eq 81
access-list outside_access_in_1 extended permit object Support-site any host 10.10.3.0
and it is not working from the outside.
What simple thing did I mess up?
11-10-2015 09:10 AM
Chris
Two things -
1) what port is the server accessed from on the outside ?
2) your port object group. The source and destination ports cannot be the same ie. the client will use a random port number.
Jon
11-10-2015 09:12 AM
So I should change the service to
object service Support-site service tcp source eq any destination eq 81?
11-10-2015 09:16 AM
I would just do -
Jon
11-10-2015 11:28 AM
Got it working, tweaked my service and changed the things you suggested and it works Also, the network is bigger that 10.10.3.0/24
Thanks, now I just need to create a new thread for the original port forwarding that I was trying to do from the start.
Thanks for your help
11-10-2015 01:24 PM
No problem.
If you want to include the port forwarding issue in this thread fine by me.
Jon
11-11-2015 12:11 PM
ok, here we go with the original request
I have a cisco 5515 at 216.x.x.39 and I need to forward port 46611 to an internal ip address 10.10.3.7 port 9000
my inside interface is nas-main
oustide interface is twtc
11-11-2015 12:19 PM
Assuming port is TCP -
object-network obj-10.10.3.7
host 10.10.3.7
nat (nas-main,twtc) static 216.x.x.39 service tcp 9000 46611
access-list outside_access_in permit tcp any host 10.10.3.7 eq 9000
Note you may have called your acl twtc_access_in, not sure.
Basicaly just add it to the acl already there.
Jon
11-19-2015 12:44 PM
I haven't had a chance to do this port forward yet,
But the group is requesting that I enable one of the access rules I disabled
access-list TWTC_access_in extended permit object WEBAccess-FW-Port-1 any object WEBAccess-FW
I can see it in running config. but I can't see it in the ADSM. Also, I am not sure how to enable it in command mode
11-19-2015 02:31 PM
Not sure I follow.
What acl is applied to the outside interface at the moment ?
Do you have a NAT statement setup for that access ?
Jon
11-19-2015 02:33 PM
there isn't one, this is one of the ACL's that was turned off, when I had the big issue a month ago.
Yes there is a nat statement setup, just have to enable the ACL I think. I had turned off all global ACL's
