02-16-2024 08:36 PM - last edited on 02-16-2024 09:32 PM by shaiksh
Hello Afternoon Everyone,
I have the following topology, two ebgp to two PE routers, each BGP is terminated in a different VRF.
Two router different vrf how to connect new links NNI ebgp peer and how to share the route on router ? possible without create new vrf each side?
02-16-2024 09:13 PM
check some examples :
02-16-2024 10:44 PM
Hello @francis saw
No need of a new vrf.
Established the new eBGP peering between the 2 routers since their own VRF.
R6/vrf RED ----eBGP---- vrf BLUE/R7
02-17-2024 12:09 AM
You can config vpnv4 between two router
Then in each router use export/import to advertise/install the route between different vrf
MHM
02-17-2024 01:41 AM
this lab in case you need to check how we can use vpnv4 to solve this issue
02-17-2024 02:36 AM
Hello
The new connection between differing ASNs do not have to be in any VRF they can be peer via the global route table (GRT),
You could then create a vrf import map at each GRT table site and advertised the routes from each vpn site across that new GRT bgp peering. (See attached example).
02-17-2024 03:19 AM
You keep the interface on the new links under the same VRF, and configuration wise they peer from that vrf. Both ends will not know the other side.
R6 (e0/1) vrf RED ----eBGP---- vrf BLUE (e0/1) R7
if you using MPLS on that new link, than you just need to import/export RT
