11-30-2014 09:00 PM - edited 03-05-2019 12:15 AM
Hello
i have one cisco 3750 switch and two link is terminated on this this switch.
first is bsnl LL ( four real ip's )
second is our private network link.
i want to configure failover condition with two above links. if our private network link will down then auto switch on bsnl network and when bsnl link down then auto switch on our private network.
please help me...
12-01-2014 05:53 AM
Hello
There is a few options you can use, however before then can you provide a bit more information?
Are you using dyamic or static routing@
Presently is all of you traffic going via the internal link?
res
Paul
12-01-2014 09:03 AM
our private netwwork is point to point ....
in switch we only define default gateway...
yes all traffice going via internal link...because of in pc we will give our private network ip...
12-01-2014 09:48 PM
Himanshu,
Do you mean static routes are configured? If yes you can configure IPSLA and track with static routes.
Sathvik
12-01-2014 06:11 AM
We need more info. Are "bsnl" and "private" uplinks? Where will traffic be sourced and what is the destination? Can you please provide a diagram?
12-01-2014 08:59 AM
yes "bsnl" and "private" links are uplinks..
presently source and destination are depend on ip given in the pc...
if we give real ip in the pc then it will go on bsnl and when we will give in private ip then it will go on through our private network .
