Two ip nat command
CHUN FAI LAW
I would like to know more about the concept of nat command:
I am going to do some load balancing for router traffic, e.g. 10.1.0.X traffic use gi0/0.1 and 10.2.0.X use gi0/0.2
what is the result if two nat command present?
int gi0/0.1
ip nat outside
int gi0/0.2
ip nat outside
int gi0/1
ip nat inside
ip policy route-map nwt-vlanvip
ip nat source list 10 int gi0/0.1 overload
ip nat source list 10 int gi0/0.2 overload
ip route 0.0.0.0 0.0.0.0 int gi0/0.1
access-list 1 10.1.0.0 0.0.0.255
access-list 2 10.2.0.0 0.0.0.255
access-list 10 10.1.0.0 0.0.0.255
access-list 10 10.2.0.0 0.0.0.255
route-map nwt-vlanvip permit 10
match ip address 1
set int gi0/0.1 gi0/0.2
match ip address 2
set int gi0/0.2 gi0/0.1
7 Replies 7
CHUN FAI LAW
i test the command with same source list will be replace each other
both are calling acl 10 and natting 10.1.0.x and 10.2.0.x subnet
match ip address 1
match ip address 2
NOw See Route Map
nwt-vlanvip
Iits calling acl 1
10.1.x is routed towards
gi0/0.1 gi0/0.2
its calling acl 2
10.2.x is routeed towards
*** Do Rate Helpful Posts***
Jawad
cadet alain
you must use route-maps in your NAT statements like this:
route-map OVERLOAD_1
match interface g0/0.1
route-map OVERLOAD_2
match interface g0/0.2
ip nat source route-map OVERLOAD_1  int gi0/0.1
ip nat source route-map OVERLOAD_2 int gi0/0.2
Also in your PBR you are specifying a multipoint outgoing interface and it will have the same behaviour as specifying an exit interface in a static route, that is if the next-hop has proxy-arp disabled the ARP process will fail and your PBR and NAT won't be working correctly so you better change the interface by next-hop.
Alain
Is it match interface under the route map that means, if the packet is going to go out though int gi0/0.2 will use the second nat command for tranlate the header? This kind of setting seems can doing for load balancing and redundancy issue, thx so much!!
I think if i doing with this setting would be better!!!
int gi0/0.1
ip nat outside
int gi0/0.2
ip nat outside
int gi0/1
ip nat inside
match ip address 1
set ip next-hop 1.1.1.1
match ip address 2
set ip next-hop 2.2.2.2
don't forget the keyword inside in your NAT statements: ip nat inside source ...
Alain
yes exactly as routing is done before NAT if you've got multiple NAT outside interface then you need to tell the router how a packet routed out an exit interface will get natted.
Regards.
Alain
