Two_ISP Issue
MUHAMMED SHAFI
Level 2
Level 2
Dear All,
I need help from your side..
I have one of my customer have cisco 2951 Router with two ISP and two  ADSL module .i already configure one ADSL module.rit now customer want secondISP ( ADSL) module configuration superate netwok because customer have Access pont they want connect directly to router is it possible
1st ISP already running but customer requirement 2nd ISP superate network with Access pont  not redundancy
could you please give any idea and configuration
I am waiting for your replay
5 Replies 5
rais
Level 11
Level 11
As I understand you want to have two ISP connections on the same 2951 router.
If you want to have two separate networks you can create a vrf for the new ISP and the customers who will be on the separate network.
Otherwise you may have to do some policy routing keeping in view what source addresses are NATed to what ISP address.
HTH.
your tellling PBR configuration
canero
Level 3
Level 3
You may do nat with seperate overload commands for two internet facing interfaces, 2 acls for lan and wireless users provide isps chosen seperately
HI,
You can Create Two ACL
Like ACL 1 For 1 ISP
in this acl you will have Source like 192.168.10.x
permit ip 192.168.10.0 0.0.0.255 any
ACL2 For 2nd ISP
in this acl you will have source like 192.168.12.x
permit 192.168.12.0 0.0.0.255 any
Now You can do PBR
Create Router MAP
Route-map RM-INTERNET permit 1 (For ISP1)
match ip address ACL1
set ip next hope (1st ISP Gateway)
Router-map RM-INTERNET permit 2
match ip address ACL2
set ip next hope (2nd ISP Gateway)
You can apply that Route MAP to inside LAN interface of Router.
Of if u have Sub Interfaces
You can Create Two Route MAP Seperetely with differenet Names.
***Do Rate Helpful Posts***
Jawad
thanks....all i have to try this...
