two routers in same subnet
hi we have two routers and they have controller modules.
there are two sites and and the equipments on both sides have to be in same subnet suppose 172.x.x.x
anybody has worked with such a scenerio.
if u people have any idea then pls post.
your replies will be highly regarded.
Amit Singh
Hi Sandeep,
Please see my post on the link below. The same situation was faced by the poster in the post below and IRB has helped in achieving the thing that you are looking for.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dddc34d
HTH,please rate if it does.
-amit singh
jain.nitin
Level 3
Level 3
Hi Sandeep, I appreciate if u just explain wht u want to achieve & if u can just paste the line diagram of the current network. It will help us to solve ur problem.
Ninja
jatin thanks for your reply
this is the diagram u will find in attachment.
the bridges are actually routers with controllers module.and we just want the routers to act as bidges.
also m giving you the ip addressing.
Amit Singh
Hi Sandeep,
-amit singh
