Two serial routers interconnection
marekduba
I have two 1603 routers and I want to interconnect them via serial interface.
Is that possible?
Which cables do I need?
thx a lot
The built-in serial adapter in the 1600 series allows data rates up to 2 Mbps.
--Leon
leonvd79
Level 4
Level 4
Hello Marekduba,
If you want to create a back-to-back connection between the DB60 serial interfaces you'll need a DB60 (DTE) to DB60 (DCE) cable.
You can find these cables on this website: www.anthonypanda.com or try eBay for a competitive offer.
--Leon
* Please rate posts.
Thanks a lot leonvd79
How fast is the back-to-back connection between two serial interfaces in kbps?
--Leon
