Two VPN Tunnels on serial Interface
CPU4185
Two Companys want to use one serial Connection beween two routers. The networks 10.28.228.0 and 10.28.229.0 belong to the one company and the networks 10.29.72.0 and 10.29.106.0 to the other company. For separate causes we want to create two VPN Tunnels with IPsec. The max. Bandwith is 2MB/s. The configuration on the serial Subinterfaces it isn't possible to encapsulation ppp in our routers.
Without Subinterfaces and one VPN Tunnel with IPsec on the serial interface with ppp its working fine.
version 12.4
service timestamps debug datetime
service timestamps log datetime
service password-encryption
hostname beh2turm
boot-start-marker
boot system flash:c1841-advsecurityk9-mz.124-23.bin
boot-end-marker
logging buffered 51200 warnings
no logging rate-limit
enable secret 5 ****
aaa new-model
aaa authentication login conmethod group tacacs+ enable
aaa authentication login vtymethod group tacacs+ enable
aaa authentication enable default group tacacs+ enable
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
aaa session-id common
clock timezone CET 1
clock summer-time CEST recurring last Sun Mar 2:00 last Sun Oct 3:00
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip domain name gsta.verwalt-berlin.de
crypto pki trustpoint TP-self-signed-3134403343
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3134403343
revocation-check none
rsakeypair TP-self-signed-3134403343
crypto pki certificate chain TP-self-signed-3134403343
certificate self-signed 01
  30820257 ****
        530A9F
  quit
archive
log config
  hidekeys
crypto isakmp policy 12
encr 3des
hash md5
authentication pre-share
crypto isakmp policy 14
encr 3des
hash md5
crypto isakmp key halfspeed address 10.29.40.49
crypto isakmp key halfspeed address 10.29.40.17
crypto ipsec transform-set encrypt-3des esp-3des
crypto map BEH 12 ipsec-isakmp
set peer 10.29.40.17
set transform-set encrypt-3des
match address 130
crypto map GB 14 ipsec-isakmp
set peer 10.29.40.49
match address 150
interface FastEthernet0/0
description zum Grundbuch
ip address 10.28.229.1 255.255.255.0
no shutdown
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.29.106.240 255.255.255.0
ip helper-address 10.29.80.56
ip helper-address 10.29.80.55
ip directed-broadcast
duplex auto
speed auto
interface Serial0/0/0
no ip address
interface Serial0/0/0.1
description zur STA
autodetect encapsulation ppp
bandwidth 1500000
ip address 10.29.40.18 255.255.255.252
crypto map BEH
interface Serial0/0/0.2
description zum AG
bandwidth 500000
ip address 10.29.40.50 255.255.255.252
crypto map TUNNEL-GB
no ip forward-protocol nd
ip route 10.28.228.0 255.255.255.0 10.29.40.49
ip route 10.29.50.0 255.255.255.0 10.29.40.17
ip route 10.29.60.0 255.255.255.0 10.29.40.17
ip route 10.29.80.0 255.255.254.0 10.29.40.17
ip route 10.29.82.0 255.255.254.0 10.29.40.17
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging origin-id hostname
logging 10.29.50.2
access-list 130 permit ip any any
access-list 150 permit ip any any
snmp-server community public RO
snmp-server community private RW
snmp-server enable traps tty
tacacs-server host 10.29.50.2
tacacs-server directed-request
tacacs-server key 7 ****
control-plane
banner motd ^Geraet mit AAA konfiguriert!^
line con 0
exec-timeout 3 0
password 7 ***
login authentication conmethod
line aux 0
line vty 0 4
exec-timeout 20 0
privilege level 15
password 7 ***
login authentication vtymethod
transport input ssh
line vty 5 15
exec-timeout 5 0
privilege level 15
password 7 ***
transport input ssh
scheduler allocate 20000 1000
ntp clock-period 17178612
ntp peer 10.29.40.17
end
Can you help me, how to configure two VPNs over a serial interface (see appendix)?
Best regards,
Matthias
Richard Burts
Matthias
Unfortunately I do not believe that it is possible to set up 2 separate VPN tunnels running over a single serial interface between the same 2 routers.
Would it be feasible to run a single VPN tunnel to transport traffic for both companies over the serial link. And to use ACL to make sure that a source from company 1 could only access destination of comapny 1?
Rick
Rick
Richard Burts
Matthias
Rick
Rick
Hello Rick,
thank you for your answer. I think the solution with ACL is feasible for our subject.
Best Regards
Matthias
Matthias
I am glad that my suggestion may point you toward a solution that could work for you.  Thank you for marking this question resolved (and thanks for the points). It makes the forum more useful when people can read a question and can know that they will read responses which did point toward a solution. Your marking this question will help other readers to make effective use of this thread in the forum.
Rick
Rick
