Txload 255/255 on Gi0/0 and Serial0/0/0 even no traffic- Cisco 1921
anilraj_003
Hi Team,
We are facing an issue that Txload-255/255 in cisco 1921 router. Please suggest how to resolve this.
Logs are here -
sh int gi0/0
GigabitEthernet0/0 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is 6073.5c60.9a00 (bia 6073.5c60.9a00)
  Description: ***LAN***
  Internet address is 10.113.151.1/25
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 255/255, rxload 1/255
  Keepalive set (10 sec)
  Full Duplex, 100Mbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:21, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 34000 bits/sec, 8 packets/sec
  5 minute output rate 76000 bits/sec, 6 packets/sec
     99225 packets input, 21311385 bytes, 0 no buffer
     Received 495 broadcasts (0 IP multicasts)
     0 watchdog, 140 multicast, 0 pause input
     114096 packets output, 116538432 bytes, 0 underruns
     168 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Show version--
S1-53D-D053-R#show ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.2(2)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 29-Feb-12 19:19 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
S1-53D-D053-R uptime is 2 hours, 39 minutes
System restarted at 03:38:57 UTC Sat Jul 7 2018
System image file is "usbflash0:c1900-universalk9-mz.SPA.152-2.T1.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FGL163325RW
2 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
249840K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1921/K9          FGL163325RW
Technology Package License Information for Module:'c1900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    EvalRightToUse securityk9
data          None          None           None
Hi Leo
I tried for IOS up gradation and same has been done. Now TX load is showing normal . No issues.
RCA - IOS Bugs.
Thanks.
Anil
5 Replies 5
Leo Laohoo
I can see a lot of outbound traffic right there.
Ok. But as per user, no traffic flow.
Not sure about that.
So this port is connected to the LAN, which means a switch, right?  So try and find out which port is chatting.  Another thing to do is disable all the downlink port and see if the numbers change after 5 minutes.
Enable IP accounting on the router to determine who is the top talker.
Hi Leo,
Please see log again..here output (under 5 mints.) is zero, but Txload is 255/255. I think something is IOS bugs related issue. Please guide.
  Last input 00:00:05, output 00:00:00, output hang never
     132473 packets input, 32275072 bytes, 0 no buffer
     Received 1514 broadcasts (0 IP multicasts)
     0 watchdog, 274 multicast, 0 pause input
     109901 packets output, 75098721 bytes, 0 underruns
     0 unknown protocol drops
S3-523-D052-R#sh clock
13:27:53.482 IST Sat Jul 7 2018
S3-523-D052-R#
Hi Leo
RCA - IOS Bugs.
Thanks.
Anil
