Type 5 external LSA remove
JurajK
Hi I've written bad IP address as I redistributed the loopback interfaces into OSPF.  I want to remove the IP address from ospf database but the command
 no network A.B.C.D  wildcard mask area X
under the router ospf subinterface has no effect. I wanna point it out that bad IP address has no interface
R1(config)#route-map TST
R1(config-route-map)#match interface lo1
R1(config)#router ospf 1
R1(config-router)#router-id 0.0.0.1
R1(config-router)#network 10.1.9.1 0.0.0.0 area 0
R1(config-router)#redistribute connected route-map TST subnets
R1(config-router)# no network 10.1.9.1 0.0.0.0 area 0
Thanks for help
Hello @JurajK ,
I see
try to use
clear ip ospf redistribution
or
clear ip ospf process
Hope to help
Giuseppe
6 Replies 6
Giuseppe Larosa
Hello @JurajK ,
so it should be already removed from OSPF database
check with
show ip ospf database external <prefix>
Hope to help
Giuseppe
JurajK
hi . perhaps did I set the question no correct. Then LSA  ( External network number ) is still hier. I want remove the advertising that LSA with  incorrect prefix
JurajK
Can you more elaborate
LO now which IP/mask it have ?
You can defualt address under LO then add IP again
The ospf will advertise the new IP
MHM
Hello @JurajK ,
I see
try to use
or
Hope to help
Giuseppe
JurajK
perfect. perhaps trivial but i couldn't find it before. I have used always the possibilities with "no ...."
Thanks a lot
