Unable to access websites with differents ports through rv325
JimGyt
Hi, i'm new at cisco devices. I recently install a router rv325 with vlans. All the vlans can access internet without problem. But through the router, i can't access some website. I am not sure but i think it is a problem with the used port. For example, i can not access to a website like https://example1.com:880 or http://example2.com:123. But i notice that it work if i just go to the 80 port for http and 443 on https. I don't have any content filtering or application control activate. Did i miss something? Thanks
Im not really sure but it looks like website configuration, have you tried from other Internet access, from cellphone or Internet in other place?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thank you for your answer. It works on cellphone, it's only when i am plug behind the cisco.in my case i am trying to connect to the interface of a nas or a recorder which are located in a other areas.
