Unable to communicate across router
Minuit
Beginner
Beginner
Set up two dummy networks so that i can use them in my coursework for testing however i cannot get the two to communicate currently. They are set up with ipv6.
These are the commands ive used. Thanks in advance
R0(config)#interface fastethernet0/0 R0(config-if)#ipv6 enable R0(config-if)#ipv6 address 2000::1/64 R0(config-if)#no shutdown
The first network will use addresses starting from 2000:1::/64 and the second network will use addresses starting from 2000:2::/64. The link between both the routers will have IP addresses 2001::10/64 and 2001::20/64.
Device
Interface
IP address
R1
FastEthernet0/0
2000:1::1/64
FastEthernet0/1
2001::10/64
PC0
FastEthernet
2000:1::2/64
PC1
FastEthernet
2000:1::3/64
R2
FastEthernet0/0
2000:2::1/64
FastEthernet0/1
2001::20/64
PC2
FastEthernet
2000:2::2/64
PC3
FastEthernet
2000:2::3/64
R1(config)#ipv6 unicast-routing R1(config)#ipv6 route 2000:2::/64 2001::20
R2(config)#ipv6 unicast-routing R2(config)#ipv6 route 2000:1::/64 2001::10
I have been able to open your file (in Packet Tracer 7.1). Your PCs do not have an IPv6 default gateway configured, so they cannot get out of the local subnet...
10 Replies 10
DaSt-1986
Beginner
Beginner
Please provide more details; what do you mean with 'not communicating correctly'? Do you receive ARP replies; are your routing tables filled? Please post a readable config file so we can see the nature of your problem.
As in according to packet tracer they are UP but i cannot ping or tracert and im unsure how i check results for simple PDU's
Georg Pauwen
VIP Master VIP Master
VIP Master
you mention two routers, but you have posted partial configurations of three routers (R0, R1, R2). What is connected to what, which PCs to which routers, which networks to which routers ?
Check the below for a sample configuration of three routers with IPv6 and static routing:
https://www.cisco.com/c/en/us/support/docs/ip/ip-version-6-ipv6/113361-ipv6-static-routes.html
Apologies, this was partly copied from my document. r2 is r1 main routers are r0 and r1.
This is how it looks in packet tracer
https://i.imgur.com/470wg0R.png
If you do this in Packet Tracer, post the .pkt file (save it as pkt then rename it to jpg, otherwise you cannot upload...)
I'm looking at your network topology (which is missing interface names...) and the configuration you posted (which has wrong router names) and cannot see anything that might be wrong. Please post the packet tracer file or give us the output of the following commands for both routers:
show ipv6 route
show run int fa0/0
show run int fa0/1
 I've created this myself and it seems to be working (see attached packet tracer file, rename to .pkt)
This is it here, tried the version you posted but it said the version i was using was not compatible
I am going to take us a step back here in-order to see what exactly is failing.
Is the problem you are facing one that the PC cannot ping through the router to the remote end? How have you configured IPv6 on the PC's in your topology. From the screenshot i see pings failing from a PC and not from a router. Are you using SLAAC to configure the PC's of DHCPv6? Are the IPv6 flags esp the on-link flag configured correctly on the router?  I could be getting this wrong but if you can advise a few things..
1. Can the routers ping each others directly connected interfaces
2. Can the routers ping each others remote IPv6 interface the ones the PCs connect to
3. How have you configured addressing on the PC's
4. Can the PC's ping their own default router
T
The Ip's are static.
PC to PC works within the its own subnet.
Yes
IP's are static and the ip's are as i left in my orginal post
Yes
Recognize Your Peers
