Unable to establishing link between two routers with different subnet
kasulasaiganesh
I have two ISR 4351 routers and I'm trying to  esatliblising connectivity between 2 routers with serial interface. Is it possible to connect with different subnets?
R1# serial 0/0/0
ip address 192.168.1.1/24
encapsulation ppp
R2# serial 0/0/0
ip address 192.168.2.1/24
encapsulation ppp
38 Replies 38
Yes! I did same thing on R2 also
Again (please), what's the actual default route statements?
Oh, forgot to ask, have you tried it with same subnet interface IPs?
Yes I tried with same subnets it's working.
You mean disjoined subnet in p2p address ?
BB
we have suggested some config, have you got chance to read and tried ?
BB
kasulasaiganesh
It's working. But my question is it possible to connect with different subnets.
Hello
It is possible to do, You will need to ultise virtual-templates to accoplish it, try the following:
RTR1
int ser 0/0/0
enacp Fr
clock rate 64000
no keepalives
frame-relau map ip 192.168.2.1 121
frame-realy interface-dlci 121 ppp virtual-template 12
int virtual-template 12
RTR2
int ser 0/0/0
ip address 192.168.2.1 255.255.255.0
enacp Fr
no keepalives
frame-relau map ip 192.168.1.1 121
frame-realy interface-dlci 121 ppp virtual-template 21
Kind Regards
Paul
Thanks Paul  it's really great effort.  Now both routers are communicating.
But I'm not able to ping from PC1 to Router2. Please kindly look at that problem.
RTR1
# interface FastEthernet0/0
ip address 172.16.1.1 255.255.255.0
duplex auto
speed auto
# interface Serial0/0
encapsulation frame-relay
no keepalive
clock rate 2000000
frame-relay map ip 192.168.2.1 121
frame-relay interface-dlci 121 ppp Virtual-Template12
# interface Virtual-Template12
# ip route 0.0.0.0 0.0.0.0 Serial0/0
RTR2
ip address 172.16.2.1 255.255.255.0
duplex auto
speed auto
no keepalive
clock rate 2000000
frame-relay map ip 192.168.1.1 121
Any additional routing  is required ?
post config ip and gateway of both pc and ip route of both router
R1# ip route 0.0.0.0 0.0.0.0 Serial0/0
R2# ip route 0.0.0.0 0.0.0.0 Serial0/0
PC1        PC2
That's likely because @paul driver's  (creative) approach would still require additional route statements.  For example, R2 wouldn't know where to send traffic for the 172.16.1.0/24 network.  (What I had suggested, using default routes on R1 and R2, which from @DaviRocK!'s testing works, may work, for your just posted topology.  [I'm assuming PC's have local router as gateway.])
@Joseph W. Doherty  I think we are missing some additional route statements.
Yes OR the "correct" route statements.
R1 and R2 "know" of all directly connected networks.
A default route, on both R1 and R2, directing all non-connected networks, to the other router, would solve the routing issue in your last posted topology.  BTW, this also would still be true if your R1<>R2 link shared the same network.
@Joseph W. Doherty @paul driver @DaviRocK!
It's working with static routes. Why? default route is not working. Anyway we got a solution finally. Thanks @paul driver @Joseph W. Doherty @DaviRocK!
R1:-
R2:-
PC-1        PC-2
