Unable to ping the LAN side from the outside
pcastill1976
Hey Guys,
I am not able to ping the LAN side of my network GigabitEthernet0/0/1 from the outside.
I can ping .225 GigabitEthernet0/0/1 from the router and my FW .226
I can't access the FW from outside of my network
This is the running config
Building configuration...
Current configuration : 1861 bytes
! Last configuration change at 22:42:37 UTC Wed Feb 8 2017
version 15.4
no platform punt-keepalive disable-kernel-core
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
no ip icmp rate-limit unreachable
no ip domain lookup
ip name-server 205.171.3.65
ip name-server 205.171.2.65
ip name-server 8.8.8.8
subscriber templating
license udi pid ISR4331/K9 sn FDO19261JAM
redundancy
 mode none
ip tftp source-interface GigabitEthernet0
interface GigabitEthernet0/0/0
 description Broadband CenturyLink Internet
 ip address 208.44.15.210 255.255.255.252
 ip nat outside
 negotiation auto
interface GigabitEthernet0/0/1
 description LAN To Firewall
 ip address 216.207.122.225 255.255.255.240
 ip nat inside
 ip access-group 102 in
 ip access-group 102 out
 negotiation auto
interface GigabitEthernet0/0/2
 no ip address
 shutdown
 negotiation auto
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 208.44.15.209
ip access-list standard Access
 permit 216.207.122.0 0.0.0.255
access-list 102 permit icmp any any echo-reply
access-list 102 permit tcp any any eq 443
access-list 102 permit ip any any
control-plane
line con 0
 password
 login
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 password
 login
end
Do I have the right access list or IP route?
2 Accepted Solutions
1- Your access-list does not have any effect on pinging 216.207.122.225
2- Your access-list does not have effect at all since you have allowed everything by following command access-list 102 permit ip any any
3- 216.207.122.225 is a public address. Why do you do NAT? You probably do not need NAT. If you remove the NAT statements, your problem will be solved.
4- Access-list 1 is missing: ip nat inside source list 1 interface GigabitEthernet0/0/0 overload:
Masoud
azibnaseem
Hi pcastill1976  '
As mentioned by [@m.pourshabani]  that a public IP has been configured on Gigabitethernet0/0/1, which is no need to be NAT Translated. Moreover you gave access-list 1 in your IP nat statement & access-list does not exist.
Regards'
Masoud
Thank you guys. It works now. I followed your recommendation
Hey pcastill1976 ,
Glad to hear that your problem has been resolved.
Regards'
azibnaseem
Hi pcastill1976  '
Regards'
