11-16-2016 07:34 AM - edited 03-05-2019 07:29 AM
Hi, after I upgraded this 867VAE (an IP base model) to run advsecurity it failed to boot and I then discovered these routers can only run ip base images.
So, no problem I thought, put into rommon and boot from a USB device, a procedure I very familiar with. However, I get an error indicating the file system is not ready. The drive is formatted as FAT32.
MY question, is can I recover this router by any method, or is it scrap? I had to delete the ip base image as there isn't enough space to take both.
* Additional info:
from rommon when I enter dev I see usbflash0: as an option
But dir and dir usbflash0: results in:
File system is not ready to use
Please reset before access file system
reset results in a reload.
I found a reference which states that the USB has to be FAT 32 and less than 2Gb which is is.
Solved! Go to Solution.
11-16-2016 12:00 PM
I am suspecting the USB stick is not supported. Let me explain: There are some USB sticks which works in one IOS but won't work with another. This is common. So, in your case, it may work when the router is working but won't work when the router is in ROMmon.
The only way around this dilemma are:
1. Find another USB stick;
2. TFTPdnld; or
3. XModem
11-16-2016 12:00 PM
2. TFTPdnld; or
3. XModem
11-17-2016 01:00 AM
Thanks Leo,
I've already tried several USB sticks, including a Cisco one.
Looks like I'll have to fallback on the older trusted recover methods then, I was hoping for an easy recovery process!
Cheers,
Andy
11-17-2016 01:08 AM
Thanks for the ratings, Andy.
There's only one culprit that I can think of.
Some models of the Cisco 870 comes with USB ports (and some don't). But no matter what i do, USB support with ROMmon do NOT seem to work.
I am suspecting this is the case, i. e. USB support in ROMmon was never intended.
11-17-2016 04:37 AM
Having spent another hour or so looking at this I've decided its scrap. The tftpdnld option is provided, and an option to boot up from an external process, but both result in the following message:
File system is not ready to use.
When I reset it restarts then outputs:
Wrong IOS image on IPBASE Router
System reload in 5 seconds
There is no xmodem facility.
Its going in the bin!
11-17-2016 12:36 PM
WTF!
No Xmodem? Serious?
TFTPdnld doesn't work either?
Sounds like a friggin' bug to me. Can you, at least, raise a TAC Case for this?
11-17-2016 01:02 PM
on a side note, have you tried:
#format usbflash0:
directly from the router ?
11-17-2016 01:18 PM
Yes and no.
If the router or switch is front of me, I'd do it then and there. If not, then FAT16 is suffice.
11-17-2016 01:24 PM
The idea is, if IOS formats the USB, it should be able to read from it...;)
Either way, FAT16 supports 1GB only. I think I read somewhere in the thread that FAT32 is required...as far as I know it is FAT16 ?
11-17-2016 01:43 PM
Errrr ... You're missing an important step. Step 1: If the appliance can DETECT the USB stick then one should be able to format the USB stick.
I mean, if the appliance cannot even detect or throws up an error then what's the use, right?
Maybe, but I have a 8 Gb USB stick and I have formatted it using the appliance. Works well with Catalyst 2K & 3K, however, I can't get it to work with Cat 4K and 6K. Another proviso is some IOS will go "nuts": Works well with Catalyst IOS 12.2 but stops working with Catalyst IOS 15.0, however, Catalyst IOS version 15.2 works well. Go figure!
11-18-2016 09:10 AM
For info here is the output from another session this afternoon, shows the available commands and the results when trying to access the various file systems.
System Bootstrap, Version 15.1(4r)M2, RELEASE SOFTWARE (fc1)
Copyright (c) 2011 by cisco Systems, Inc.
C860VAE ipbase platform with 256 MB of main memory
[BREAK KEY]
monitor: command "boot" aborted due to user interrupt
rommon 1 > help
alias set and display aliases command
boot boot up an external process
confreg configuration register utility
delete delete file from flash: file system. delete <flash:filename>
dev list the device table
dir list files in flash file system
format Format flash: file system or disaster recovery for flash:
help monitor builtin command help
history monitor command history
meminfo main memory information
repeat repeat a monitor command
reset system reset
set display the monitor variables
showmon display currently selected ROM monitor
sync write monitor environment to NVRAM
tftpdnld tftp image download
unalias unset an alias
unset unset a monitor variable
rommon 2 >
rommon 2 > USB inserted
monitor: command "USB" not found
rommon 3 >
rommon 3 > dev
Devices in device table:
id name
flash: flash
bootflash: boot flash
usbflash0: usbflash0
rommon 4 > dir usbflash0:
rommon 5 > format usbflash0:
rommon 6 > dir
rommon 7 > dir bootflash:
rommon 8 > boot flash
Please reset before booting
rommon 9 > dir flash:
rommon 10 >
A reset results in:
rommon 14 > reset
Booting flash:/c860vae-advsecurityk9-mz.156-2.T1.bin
boot: Launch entrypt: 0x80800000
Self decompressing the image : ####################################
11-18-2016 01:47 PM
Stupid question, Andy: Can you please post the output to the command "set"?
11-21-2016 11:12 AM
Suggest that you try either of the following:
If tftpdnld -r did not work, kindly consider sharing the complete session log. Also, what is the serial # of the brick and the exact model mentioned? If possible, please take photos of front, back and the area that has the sticker with serial#, model# and such.
The -r option in tftpdnld skips writing to flash and loads image to DRAM. If this is successful, while the router is up, use copy tftp: flash|usb0: to transfer image, proceed to reboot.
http://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/data_sheet_c78-693249.html
One line here says "Applicable to the newer C866VAE-K9 and C867VAE-K9 models" Not sure what it means precisely. This is the background for asking some of the above questions.
Kind regards ... Palani
