08-07-2020 12:00 AM
I get the following messages upgrade rom-monitor filename bootflash:asr1000-rommon.169_5r_SPA.pkg all :
ROMMON upgrade complete. To make the new ROMMON permanent, you must restart the RP. Upgrade rom-monitor on Embedded-Service-Processor 0 Target copying rom-monitor image file rsync: link_stat "rommon/mcp/FP/20G/latest.bin" (in rommon_upgrade_pub) failed: No such file or directory (2) rsync error: some files could not be transferred (code 23) at /scratch/mcpre/release/BLD-V03_16_10_S_FC3/contrib/rsync/main.c(1392) [receiver=2.6.9] Upgrade rom-monitor on SPA-Inter-Processor 0 Target copying rom-monitor image file rsync: link_stat "rommon/mcp/CC/10G/latest.bin" (in rommon_upgrade_pub) failed: No such file or directory (2) rsync error: some files could not be transferred (code 23) at /scratch/mcpre/release/BLD-V03_16_10_S_FC3/contrib/rsync/main.c(1392) [receiver=2.6.9]
Slot CPLD Version Firmware Version --------- ------------------- --------------------------------------- 0 09111601 15.3(3r)S R0 10021901 16.9(5r) F0 08041102 15.5(3r)S1
Is this problematic if the version of a firmware is not the same on an ASR1004-RP2 concerning Slot 0; R0 and F0 ??
I have this IOS version : asr1000rp2-adventerprisek9.03.16.10.S.155-3.S10-ext.bin
Thank !
08-07-2020 12:07 AM
08-07-2020 12:13 AM
- Check if the hints and or subsequent iterations in this thread can be helpful :
https://community.cisco.com/t5/routing/asr1006-cannot-upgrade-rommon/td-p/2352200
M.
08-07-2020 05:21 AM
@Leo Laohoo: I will try this version 16.12(8r)
@marce1000: md5 is correct !
Router#$:asr1000-rommon.169_5r_SPA.pkg 9e6ee99528122916fd04468a243ab783 .............................................................................Done! Verified (bootflash:asr1000-rommon.169_5r_SPA.pkg) = 9e6ee99528122916fd04468a243ab783
08-07-2020 05:37 AM
@Leo Laohoo: I do not find this version 16.12(8r) ! Only asr1000-rommon.169_5r_SPA.pkg...
08-07-2020 06:24 AM
ROMMON version 16.12(8r) for ASR 1k RP2 can be found HERE.
08-07-2020 06:45 AM
@Leo Laohoo: Yes I had found in the meantime I did not look at the right page (RP2)
This version does not work !!
ROMMON upgrade complete. To make the new ROMMON permanent, you must restart the RP. Upgrade rom-monitor on Embedded-Service-Processor 0 Target copying rom-monitor image file rsync: link_stat "rommon/mcp/FP/20G/latest.bin" (in rommon_upgrade_pub) failed: No such file or directory (2) rsync error: some files could not be transferred (code 23) at /scratch/mcpre/release/BLD-V03_16_10_S_FC3/contrib/rsync/main.c(1392) [receiver=2.6.9] Upgrade rom-monitor on SPA-Inter-Processor 0 Target copying rom-monitor image file rsync: link_stat "rommon/mcp/CC/10G/latest.bin" (in rommon_upgrade_pub) failed: No such file or directory (2) rsync error: some files could not be transferred (code 23) at /scratch/mcpre/release/BLD-V03_16_10_S_FC3/contrib/rsync/main.c(1392) [receiver=2.6.9] Router#reload Proceed with reload? [confirm] *Aug 7 12:47:06.298: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.Aug 7 12:47:21.036 R0/0: %PMAN-5-EXITACTION: Process manager is exiting: process exit with reload chassis code Initializing Hardware ... Calculating the ROMMON CRC ... CRC is correct System Bootstrap, Version 16.9(5r), RELEASE SOFTWARE Copyright (c) 1994-2019 by cisco Systems, Inc. Current image running: Boot ROM1 Last reset cause: LocalSoft ASR1000-RP2 platform with 16777216 Kbytes of main memory Rommon upgrade requested Flash upgrade reset 1 in progress ....... Initializing Hardware ... Calculating the ROMMON CRC ... CRC is correct System Bootstrap, Version 16.12(8r), RELEASE SOFTWARE Copyright (c) 1994-2020 by cisco Systems, Inc. Current image running: *Upgrade in progress* Boot ROM0 Last reset cause: BootRomUpgrade Saving cur/min version to nvram 2 *** Incorrect BIOS parameters *** *** Correcting the BIOS parameters and rebooting *** ▒ Initializing Hardware ... Calculating the ROMMON CRC ... CRC is correct System Bootstrap, Version 16.9(5r), RELEASE SOFTWARE Copyright (c) 1994-2019 by cisco Systems, Inc. Current image running: Boot ROM1 Last reset cause: Watchdog/ICH ASR1000-RP2 platform with 16777216 Kbytes of main memory Rommon upgrade requested Flash upgrade reset 2 in progress ....... Initializing Hardware ... Calculating the ROMMON CRC ... CRC is correct System Bootstrap, Version 16.12(8r), RELEASE SOFTWARE Copyright (c) 1994-2020 by cisco Systems, Inc. Current image running: *Upgrade in progress* Boot ROM0 Last reset cause: BootRomUpgrade ASR1000-RP2 platform with 16777216 Kbytes of main memory
Maximum upgrade attempts exceeded, continuing with old Rommon...
File size is 0x28717388
Located asr1000rp2-adventerprisek9.03.16.10.S.155-3.S10-ext.bin
Image size 678523784 inode num 13, bks cnt 165656 blk size 8*512
08-07-2020 06:23 PM
08-08-2020 02:07 AM
@Leo Laohoo: I'm not sure I understand everything !
I have an ASR-1004-RP2 with 16GB DRAM and 1 x ASR1000-ESP20 and 1 x ASR1000-SIP-10.
Is it possible to downgrade the IOS (not the ROMMON) to, say, 16.3.10
Currently I have the following IOS installed asr1000rp2-adventerprisek9.03.16.10.S.155-3.S10-ext.bin (03-Oct-2019 )
So I have to install IOS asr1000rpx86-universalk9.16.03.10.SPA.bin (28-Feb-2020) ??
08-08-2020 03:57 AM
08-09-2020 10:42 PM
Hi @Leo Laohoo
I have successfully downgraded the ROMMON to asr1000-rommon.163-2r.pkg
Slot CPLD Version Firmware Version --------- ------------------- --------------------------------------- 0 09111601 16.3(2r) R0 10021901 16.3(2r) F0 08041102 16.3(2r)
Now what should I do ?
Upgrade IOS to asr1000rpx86-universalk9.16.03.10.SPA.bin and try to flash asr1000-rommon.1612-8r.pkg ?
08-10-2020 02:49 AM
Upgrade the ROMMON only and reboot the router.
08-10-2020 09:32 AM
The version asr1000-rommon.1612-8r.pkg does not work !
I tried with the version asr1000-rommon.169_4r_SPA.pkg, asr1000-rommon.169_5r_SPA.pkg and does not work again.
0 09111601 16.3(2r)
R0 10021901 16.9(4r)
Only asr1000-rommon.163-2r.pkg work...
Do I have to upgrade to IOS asr1000rpx86-universalk9.16.03.10.SPA.bin to use ROMMON > 169_4R ??
08-10-2020 05:35 PM
08-07-2020 07:27 AM
check here for all possible ways: https://www.cisco.com/c/en/us/td/docs/routers/asr1000/rommon/asr1000-rommon-upg-guide.html#concept_zdm_2nx_5bb
