urgent - nat problem on a pix
pamirian76
hi,
I have a subnet 172.16.0.0 that gets into the pix from the outside interface.
what I'm trying to do is to change the source that is 172.16.x.x to something like 192.168.99.x
so basically the user with the source ip 172.16.30.30 changes to 192.168.99.X
any help would be appreciated.
pkhatri
Level 11
Level 11
You need to use Outside NAT to enable this.
Try the following config:
nat (outside) 1 172.16.x.0 255.255.255.0 outside
global (inside) 1 192.168.99.1-192.168.99.254
Hope that helps - pls rate the post if it does.
Paresh
