Urgent, Router in Endless loops
xtam1
Dear All,
i have a problem where suddenly the router failed and when i connected to its console port i logged the attached output. Also below is the last show version taken before the failure (1 week ago).
I need help to resolve this problem,
Thanks..
------------------ show version ------------------
Cisco IOS Software, 3800 Software (C3845-IPVOICEK9-M), Version 12.4(9)T1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 30-Aug-06 19:46 by prod_rel_team
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
New_Xbox_IR uptime is 15 minutes
System returned to ROM by bus error at PC 0x605A80F4, address 0x702B82E8 at 10:19:56 UTC Wed Oct 11 2006
System image file is "flash:c3845-ipvoicek9-mz.124-9.T1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3845 (revision 1.0) with 1005568K/43008K bytes of memory.
Processor board ID FTX1023A1PT
2 Gigabit Ethernet interfaces
252 Serial interfaces
10 Channelized E1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
250880K bytes of ATA System CompactFlash (Read/Write)
Harold Ritter
The error messages in the log point to the DRAM being bad. It looks like you are going to have to replace the DRAM on your 3845.
Hope this helps,
i will check that DRAM i have 2 * 512
