URL Filterning on a 871 router
warrend
I’m trying to determine what level of IOS and feature set I need on my 871 router to allow me to do URL filtering using Websense. The routers were delivered with IOS version 12.3(8)YI2 installed. Commands need to do URL filter configuration are not listed when I list out the available commands so I’m assuming I’m missing something.
pkhatri
Level 11
Level 11
You need to use one of the following feature sets for WebSense filtering on the 871s:
ADV. IP SERVICES
ADV. ENTERPRISE SERVICES
ADVANCED SECURITY
The first 2 feature sets are available for 12.3(8)YI2 while the adv. security is available with 12.4(4)T1.
Hope that helps - pls rate the post if it does.
Paresh.
