Routing
Labels
Anyone is preparing ccie service provider lab. I am looking for group where we can collaborate our study discussion so we can exchange our concepts and it helps definitely to boost preparation.Keep learning...
amjsajid by Level 1
  • 70 Views
  • 0 replies
Dear All , After having the old faithful 5515 on guard I am trying to migrate to a vFMC with a NGFW. Many issues arise with S2S and bugs in the GUI , BUT I am experiencing an other issue with a simple port forwarding. I have the same ACL - source out...
I learned that MED is applied to outbound updates , dictating the best inbound traffic into the AS, but I saw the vice-versa is also true like you can apply med for indbound updates also and it works the same right??
Hi , am trying to advertise default Mgmt-Vrf route to GRT so that other devices reachable to default route . thanks for tips and tricks . Configuration is mentioned below .  DC01-leaf03-55#show run int giga0/0interface GigabitEthernet0/0vrf forwardin...
uni1389 by Level 1
  • 535 Views
  • 5 replies
Hi GuysWhat is the typical and recommended BGP setup for typical spine and leaf networks, would it be EBGP between the spine and leafs? would each leaf be in the same or a different ASN than the other leaf? would you peer with loopacks?would it load ...
So I read this on official cisoc routing and switchin route 300-101 "Cisco IOS lists a null value for Local_Pref for eBGP-learned routes by default" , but I saw in my lab that the local preference is not null it's 100. What it means??
