Highlighted
Beginner
Use route-reflector-client in iBGP
Hi, my doubt is the next:
Ii have the next topoly:
     R5                      R6---------R7
           R4            R2
                    R3
R4,R3 and R2 belong to the same AS 100.
R5 belong to AS 200
R6 belong to AS 300
R7 is a static route.
My problem is that i use route-refelctor-client on R4 and R2 pointing R3 and viceversa, but i cant' see the routes static from R6, i already redistribute static on R6.. How can i do, only using BGP?
2 REPLIES 2
Highlighted
Beginner
Re: Use route-reflector-client in iBGP
Hi Kevin,
Can you post the bgp configuration of each routers?, posting "show ip bgp" and "show ip bgp summary"  output would also be useful..
-bava
Highlighted
Advisor
in your topology you can use R3 as the RR and  either R4 or R2 as a RR-client with the command neighbor x.x.x.x route-reflector-client.
Let's suppose R2 is a RR-client then when R3 receives an iBGP update from R2(client) it will reflect to R4( non-client) and when it receives an iBGP update from R4(non-client) it will reflect to R2(client) due to iBGP route-reflection rules.
Regards.
Alain
