Bookmark
Subscribe
510
using 6509 as router
Rosa Ladeira
Hi.
I have an old 6509.
I have being using it as a switch.
It is running CATOS.
Its configuration is :
WS-C6509 Software, Version NmpSW: 8.5(2)
Copyright (c) 1995-2005 by Cisco Systems
NMP S/W compiled on Dec  6 2005, 20:22:19
System Bootstrap Version: 5.3(2)
System Boot Image File is 'bootflash:cat6000-supk9.8-5-2.bin'
System Configuration register is 0x2
Hardware Version: 3.0  Model: WS-C6509  Serial #: TSC07040001
PS1  Module: WS-CAC-1300W    Serial #: SNI06440186
PS2  Module: WS-CAC-1300W    Serial #: SNI06090507
Mod Port Model               Serial #    Versions
1   2    WS-X6K-SUP1A-2GE    SAL0727FWKH Hw : 7.4
                                         Fw : 5.3(2)
                                         Fw1: 5.4(2)
                                         Sw : 8.5(2)
                                         Sw1: 8.5(2)
         WS-F6020A           SAL0729GX3D Hw : 2.0
                                         Sw :
4   16   WS-X6516-GE-TX      SAD061100XX Hw : 2.1
                                         Fw : 6.3(1)
                                         Sw : 8.5(2)
"Fan 1", DESCR: "WS-C6K-9SLOT-FAN 1" PID: WS-C6K-9SLOT-FAN
       DRAM                    FLASH                   NVRAM
Module Total   Used    Free    Total   Used    Free    Total Used  Free
1      130944K  72960K  57984K  15616K  13433K   2183K  512K  122K  390K
My question is ?
Does anyone know an IOS version (bgp bundle) wich could be used to have 6509 as a router?
Rosa
Reza Sharifi
Rosa,
As long as you have an MSFC (MSFC 2, 2a, 3 etc...) installed you can use it as a router.  There is no such thing as BGP bundle.  The feature sets are based on the IOS version you install and based on the amount of memory, flash card and the license you have.  For example the later IOS versions (SXI1, 2, 3, 4 etc...) are all about 150MB, so you would need a big enough flash to load the IOS.  You also need to have at least 256MB of memory or more to run the IOS.
Typically, if you have an older device, it will require hardware upgrade before you can run a newer IOS version on it.
Reza
