Using face to face DSL interfaces
marcOfBouloc
Does someone know if it's possible to setup DSL interfaces to work "face to face" (like DTE to DCE with serial interfaces)?
Thanks in advance.
lejoe.thomas
Level 3
Level 3
Hi Marc,
If your routers support G.SHDSL, then this might help,you can connect them back to back.
http://www.cisco.com/en/US/tech/tk175/tk274/technologies_configuration_example09186a0080135834.shtml
Lejoe
Hi Thomas,
Many thanks for the link. The described process works fine.
Regards.
