Using Router as DNS Server
Russell Stamey
I have customer who is in the position that they need the Cisco router to resovle internal hostnames.
Each location has a cisco router terminating an Internet connection. The customer is installing a new anti virus software that has to connect to the AV server that is located at their HQ.
The software must use a hostname and not an IP address. The hostname that it uses is the AV server.
The clients are failing to contact the server b/c they currently use the local Internet providers DNS servers.
I would like to set the Cisco up to resolve hostnames that are configured in the router, and forward request for all other traffic to the Internet DNS severs.
I am reading conflicting reports, some say this is not possible, some say it is.
The config I have currently is:
ip domain name customer.com
ip host CustomerAV 10.249.70.195
ip name-server 74.40.74.40 (ISP DNS Server)
ip name-server 74.40.74.41 (ISP DNS Server)
ip domain-lookup
ip dns server
Some articles I read say you must use the following command:
ip dns primary website.com soa  ns.website.com
I have no clue what that command is and if it must be used.
Right now, the clients are failing to resolve the internal hostnames. The IP of the Cisco has been configured as the primary DNS on the clients.
Any ideas?
Jeff Van Houten
Level 5
Level 5
This site has a good explanation,
http://stack.nil.com/ipcorner/RouterDNS/
I assume the host site has dns running on something other than a router and that it is configured to reply to dns queries for zones it is primary for, but forward dns queries for zones it is not. That would be a standard MS domain controller/dns installation. If that is the case, then I would configure the remote routers as dns caching proxies as the first article in the link above explains.
For that you can use the DNS-views that can be configred in IOS. Lets assume you wnat to send queries for "*.company.local" to your internal server 10.11.12.13, but everything else to the ISP-DNS-server. That can be done the following way:
Prepare the Regex for the domains that need a special handling:
ip dns name-list 1 permit \.company\.local
Prepare all the views, one for each different DNS-need:
ip dns view COMP
  logging
  dns forwarder 10.11.12.13
  dns forwarding source-interface Vlan254
ip dns view default
  logging
  domain timeout 2
  dns forwarder 8.8.8.8
And now tell the router which view should be used for which queries. The name-group 1 references the name-list configured at the top:
ip dns view-list DNS
  view COMP 10
    restrict name-group 1
  view default 1000
ip dns server view-group DNS
The internal server 10.11.12.13 should be the one that can resolve the name for the AV-server. If the IP is later changed, then you don't have to reconfigure all your routers that have this DNS-settings.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
