very HIGH CPU on 3750 switch stack(high CPU interupt)
danielseely
We have very high CPU on a 3750 stack switch stack we use as our core switch.
I used the documentation here to troubleshoot
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/troubleshooting/cpu_util.html#wp1034726
Our 'show cpu process' showed very high interupt values(~22%) and I got this from our debug logs:
Oct 17 21:50:58.909: ICMP-Q:Dropped Not a candidate: Remote Port Blocked L3If:Vlan300 L2If:GigabitEthernet1/1/1 DI:0xB4, LT:7, Vlan:300   SrcGPN:49, SrcGID:49, ACLLogIdx:0x0, MacDA:5057.a82c.0146, MacSA: 7819.f74e.10a6   IP_SA:118.67.104.12 IP_DA:27.111.203.116 IP_Proto:6
   TPFFD:EC000031_0000012C_00B00040-000000B4_02280000_A8E20000
Oct 17 21:50:58.909: ICMP-Q:Dropped Not a candidate: Remote Port Blocked L3If:Vlan300 L2If:GigabitEthernet1/1/1 DI:0xB4, LT:7, Vlan:300   SrcGPN:49, SrcGID:49, ACLLogIdx:0x0, MacDA:5057.a82c.0146, MacSA: 7819.f74e.10a6   IP_SA:210.129.96.39 IP_DA:27.111.203.112 IP_Proto:6
   TPFFD:EC000031_0000012C_00B0004E-000000B4_02280000_A8E20000
Oct 17 21:50:58.909: ICMP-Q:Dropped Not a candidate: Remote Port Blocked L3If:Vlan300 L2If:GigabitEthernet1/1/1 DI:0xB4, LT:7, Vlan:300   SrcGPN:49, SrcGID:49, ACLLogIdx:0x0, MacDA:5057.a82c.0146, MacSA: 7819.f74e.10a6   IP_SA:118.67.104.15 IP_DA:27.111.203.116 IP_Proto:6
Oct 17 21:50:58.909: ICMP-Q:Dropped Not a candidate: Remote Port Blocked L3If:Vlan300 L2If:GigabitEthernet1/1/1 DI:0xB4, LT:7, Vlan:300   SrcGPN:49, SrcGID:49, ACLLogIdx:0x0, MacDA:5057.a82c.0146, MacSA: 7819.f74e.10a6   IP_SA:118.67.104.69 IP_DA:27.111.203.116 IP_Proto:6
Oct 17 21:50:58.918: ICMP-Q:Dropped Not a candidate: Remote Port Blocked L3If:Vlan300 L2If:GigabitEthernet1/1/1 DI:0xB4, LT:7, Vlan:300   SrcGPN:49, SrcGID:49, ACLLogIdx:0x0, MacDA:5057.a82c.0146, MacSA: 7819.f74e.10a6   IP_SA:74.125.16.12 IP_DA:27.111.203.111 IP_Proto:6
   TPFFD:EC000031_0000012C_00B00046-000000B4_02280000_A8E20000
We are also seeing very high icmp in our cpu-interface:
#sh controller cpu-interface | i icmp
icmp              453936786  0          0          0          0
icmp              0            0
(Taken just after)
icmp              454015979  0          0          0          0
icmp              0            0
show processes cpu
CPU utilization for five seconds: 69%/23%; one minute: 72%; five minutes: 74%
Has anyone else seen this problem before or have a understanding of how to fix it?
Thx!
danielseely
We solved our problem it was caused because we were routing in and out the same L3 interface.
Fixed this issue and our CPU dropped dramatically.
How did you fix it ?
