12-11-2014 01:21 AM - edited 03-05-2019 12:20 AM
We have configured GRE tunnel between two location. Tunnel is up and working. As of now Data and Voice are allowed on GRE tunnel. But we are unable to view video of CCTV of location however we are able to ping and trace device over the GRE tunnel.
12-11-2014 05:14 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I have CCTV that runs across ordinary GRE (and GRE/IPSec and VTI) tunnels without any issue except for too large video packets will get fragmented.
Could you have a routing issue? I.e. where do your CCTV devices "know" to send their video?
12-12-2014 01:28 AM
Issue resolved after configured MTU size 1500 on interface tunnel.
Thanks..
12-12-2014 06:52 AM
Disclaimer
Posting
Ah, your configuration might have blocked fragmentation. If so, that would have broken your CCTV.
Unless your MTU really supports 1500, setting it such might allow fragmentation "transparent" to the sender.
Although your CCTV is now working, also if supported MTU isn't 1500, data traffic might be needlessly fragmented too.
If you've not already seen it, you might find this Cisco paper helpful: http://www.cisco.com/c/en/us/support/docs/ip/generic-routing-encapsulation-gre/25885-pmtud-ipfrag.html
