04-22-2010 10:31 AM - edited 03-04-2019 08:15 AM
Trying to configure Virtual firewall as per the document:
Configured the vrf like this:
ip vrf acct
and added to sub-interface
ip vrf forwarding acct
When this command is given it pops an error:
"VRF acct not configured." VRF acct is configured earlier.
Even after IP inspection rule applied or not applied same error pops up!!
Above mentioned documents states "Cisco IOS® Software Release 12.3(14)T introduced Virtual (VRF-aware) Firewall" I am using
ROM: 3600 Software (C3640-JK9O3S-M), Version 12.3(14)T7, RELEASE SOFTWARE (fc2)
Is this error due to IOS image.
Please share the experience
Subodh
Solved! Go to Solution.
04-22-2010 12:26 PM
Hello Subodh,
you need at least to configure the route distinguisher under VRF config
ip vrf acct
rd 100:101
to start the VRF effectively
the document is not correct in this part rd is mandatory cannot be omitted
Hope to help
Giuseppe
04-22-2010 12:26 PM
Hello Subodh,
ip vrf acct
rd 100:101
Hope to help
Giuseppe
04-23-2010 08:09 AM
Thanks Giuslar.
That Cisco document confused me a lots. I could configure overlaping private IP subnets and it's working.
Subodh
