VLAN configuration
arun panengal
4331 router ,
vlan
command is un recognized from the global configuration mode.
Unable to create VLANS.
only
vlan-autoconfig
command is available
2 Accepted Solutions
Hello
This is a router not a L3 switch, if you want to using dot 1 tagging then i would say you need to apply sub interfaces
Example:
int x/x
Description vlan 1
ip address xxxxxx
int x/x.2
Description vlan 2
encapsulation dot1q 2
ip address xxxxxx
int x/x.3
Description vlan 3
encapsulation dot1q 3
ip address xxxxxx
etc..
Kind Regards
Paul
balaji.bandi
4331 is Router, so it has routing features, until you have any Module (HWIC)Layer 2 switch port, the command not work ?
what are you trying to do ?
BB
6 Replies 6
Hello
Example:
int x/x
Description vlan 1
ip address xxxxxx
int x/x.2
Description vlan 2
ip address xxxxxx
int x/x.3
Description vlan 3
ip address xxxxxx
etc..
Kind Regards
Paul
Wet wireless column configuration
balaji.bandi
BB
Thanks much.Yes this was the issue. there was no layer 2 module. Thank you very much.
Translator
Community Manager
Community Manager
vlan-autoconfig
Translator
Community Manager
Community Manager
Thank you for your help!
