vlan problem
eng_adel273
The following command not working  , only receive data vlan , voice vlan  not working
interface FastEthernet0/1
 switchport trunk allowed vlan 200-210
 switchport mode trunk
interface FastEthernet0/4
 switchport access vlan 202
 switchport mode access
 switchport voice vlan 200
 spanning-tree portfast
also i can't type this command
switchport trunk encapsulation dot1q .
Switch#show interfaces f0/1 capabilities
FastEthernet0/1
  Model:                 WS-C2960-24TC-L
  Type:                  10/100BaseTX
  Speed:                 10,100,auto
  Duplex:                half,full,auto
  Trunk encap. type:     802.1Q
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
5 Replies 5
cheeseburger
Now days, the switchport trunk encapsulation dot1q is not needed. It's default on the devices when you have a trunk. You only have to change it if you want to use ISL.
I don't think you need the "switchport mode access" command. Also, if you're using portfast, I would suggest enabling bpdu guard, just to be safe.
why the  switchport voice vlan 200  is not executed.
Are you using a Cisco phone and Cisco switch? Do you have CDP enabled on the Cisco switch? These are necessary to use this. Also, I believe that older switches don't support this, I would assume that if you can enter the command it would though. Please confirm you're using a Cisco phone and CDP is enabled.
using grandstream , please help me
If you're using Grandstream phones (haven't heard of them) my understanding is this will not work. I believe you'll need to force your phone to tag the traffic and then set up the access ports as now trunk ports. I believe for the Cisco switch to show both ports as an access port for two VLANs, you need to have a Cisco phone and CDP enabled. Then Cisco does its magic with CDP.
