VLAN Routing
DommeDE
We have 4 VLANs. The first VLAN has to be connected with all three others. VLAN 2, 3 and 4 have to communicate with the first but not with each other. Is this possible with a layer 3 switch? And how?
omz
Giuseppe Larosa
Hello @DommeDE ,
yes it is possible by using extended IP ACLs applied to the SVI interfaces of the multilayer switch.
Remember of the implicit deny any in the ACL if you need to allow access to/from the internet.
Hope to help
Giuseppe
Hello
As stated @Giuseppe Larosa  you can achieve this via RACL applied to the SVI interface of vlan 2, 3, 4
Example:
ip access-list extended vlan2
deny ip any 3.3.3.0 0.0.0.255
deny ip any 4.4.4.0 0.0.0.255
permit ip any any
int vlan 2
ip access-group vlan2 in
ip access-list extended vlan3
deny ip any 2.2.2.0 0.0.0.255
permit ip any any
int vlan 3
ip access-group vlan3 in
ip access-list extended vlan4
permit ip any any
int vlan 4
ip access-group vlan4 in
Kind Regards
Paul
Joseph W. Doherty
Besides the possibility of using ACLs, to control which VLANs can access other VLANs, another option might be to use VRFs (often modern Cisco switches support at least a "lite" version).
With VRFs, each VLAN would be in its own VRF and you would allow VLAN 1 to exchange routes with the other VLANs (i.e. so VLAN 1 would know of the other VLAN routes, but the other VLANs would only know of VLAN 1 routes).
Why use VRFs rather than ACLs? Possibly a bit easier to maintain.
