Vlan
jsheriony
is there a cisco command to check the list of incoming vlans on a catalyst 4640 or at least that will give you the same output?
we're having an issue with an ethernet circuit, links are up but ping won't go through(no ACLs) and I want to see if the vlan tag from the the other side(side B) is properly reaching side A.
thanks
jsheriony
sorry. its a cisco 4948
