VLAN
yazmindiva
I am learning to configure vlan but after I configured it, the connection between PCs was not connected.Please help to solve it
M02@rt37
Hello @yazmindiva
All PCs have to be connected on a switch! Pluged like this computers can't forward anything towards the others PCs !
Best regards
sonnny
Hi, @yazmindiva
All PCs should be used as a connection between the PC and the switch, not as a connection between the PC and the PC.
harmanjs
PC is an end device and does not have the capability for forwarding the packets. If you have configured VLANs on a switch, connect all PCs to the switch and assign the interfaces in the correct vlan.
