vlsm subnetting
dave dave
hi! I'm trying to allocate IP range to be used in 4 sites. Pls advise which allocation is better? Option1 or Option2? and what's the reason for that? Thanks.
Option1
Network            Remarks
10.100.8.0/21      SiteA (main site)
10.100.4.0/22      SiteB
10.100.2.0/23      SiteC
10.100.0.0/23      SiteD
Option2
Network            Remarks
10.100.0.0/21      SiteA (main site)
10.100.8.0/22      SiteB
10.100.12.0/23      SiteC
10.100.14.0/23      SiteD
andrew.prince
Level 10
Level 10
It would all depend on the current number of:-
1) Servers
2) Printers
3) User Machines
4) Wireless Devices
5) Other IP Enabled devices
6) Future Growth
PER SITE
Do your numbers - and see if the above fits all requirements.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind.  Usage of  this posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Don't think it matters much whether you allocate up or down, however assigning address blocks for certain purposes might be better.  For example all 4 sites could have a /21 address block; each site's block is allocated similarly.  If the sites differ so much in size that you don't want to "waste" a /21 on each, then you might have a range for /21s (all under the same higher aggregate) and another block/aggregate for smaller sites.
What you want to do is have an address assignment scheme such that you can pretty easily form logical address tree structures where you can aggregate address blocks.
For example each site has a /20, buildings /22s, floors /25.
