Voice enabled 2800 series router
itindia
Would like to know the model in cisco 2800 series having voice capabilty.Is there any specific separate module for that?
I heard 2811V/K9 can serve the purpose.
Just need expert opinion.
Reg,
Sushil
paolo bevilacqua
All 2800 routers have voice capability.
You need:
1. the voice interface card.
2. the DSP, that is a module that fits internally.
3. the appropriate image.
You can check what you curretnly have with "show ver" and "show diag".
