Voip phones are not working
Hi Experts,
I have configured one data vlan 66 & voice vlan 69 . These two vlans are leared in switch1 & switch2. Switch 1 & switch2 are POE access switches. Pc & Voip phone connected in switch 1 are working fine . But voip phone connected in switch2 is not working , Voip phones are not getting power.
Thanks & Regards,
Suryakant
Reza Sharifi
Can you post the configs from both switches?
Also, are they the same model switches and run the same IOS?
Reza
Nagaraja Thanthry
Can you check to see if the Voice VLAN is allowed across the trunk between
the two switches? Also, if you are not getting any power, please check "show
power inline" and see if there is an issue with power delivery from the
switch side.
Hope this helps.
NT
