- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-18-2009 03:19 PM - edited 03-04-2019 06:06 AM
Hi there
I am new to vpls and trying to get some design advice. We have vpls from the carrier and I am thinking of implement it with ospf as bgp need static peers.
The offices are in US,Europe and Asia.
I was thinking of two options:
a) Setup OSPF local within the continents and do bgp to tie the continents redistributing the summarized routes via bgp.
b) Do ospf only even between the continents no bgp.
If anyone has design it or experience with vpls, please give me you your feedback.
I will apprecaite it very much.
Thank you
Regards.
Solved! Go to Solution.
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-19-2009 12:31 AM
Hello Mehdi,
how many sites are involved?
if they are many you need to think of a two levels hierarchy if they are in the order of several tens an OSPF only approach can be enough.
see for example this design guide
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/ngwane.html
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-19-2009 12:31 AM
Hello Mehdi,
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-19-2009 06:30 AM
Hi Giuseppe,
Thank you for response. It's definitely helps. For now, I think it will be about 10 sites and the most it will increase will be 20.
Should I go with the OSPF only approach? and tie them with areas?
Thank you
Mehdi.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-19-2009 11:44 AM
Hello Mehdi,
the number of sites 10-20 shoild mean up to 20-40 routers connected to the VPLS.
I recommend using default OSPF network type broadcast to reduce OSPF load on devices (it reduces the number of OSPF adjacencies that are needed with the DR and BDR election).
the VPLS ip subnet(s) can be placed in OSPF area 0 with internal subnets of each site placed in non zero areas.
This design allow for route summarization at area boundary that improves OSPF stability over the VPLS.
Another important note is to avoid as possible any form of redistribution:
instead of using redistribute connected for client vlans that generate external routes it is better to use:
network x.x.x.x area y
passive-interface type z/k
this allows for fine route control allowing also route filtering at area border (if needed now or in the future).
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-20-2009 05:57 AM
Hi Giuseppe ,
Thank you for your precious advice as it is making me realize how much worth netpro is when it comes to getting some advice from people with knowledge on the subject.
In the past, I have been using rip,eigrp and bgp. Have not used ospf and is a learning curve aswel.
What I have understood from your recommendation is that to use all OSPF, define each sites router which holds the vpls connection as area o.
Using a bigger subnet, setup interface that connects to the area 0 as using the same subnet for the vpls handoff.
e.g: One VPLS cloud and asigned a /24 subnet for all the sites interfaces connected to the cloud.
Subnet asigned: 192.168.116.0.24
Site# 1 ---Site# 2---Site# 3
Site#1 (has two router 1 & 2 and a switch)
e.g Router #1 is an (ABR)router which is directly connected to Interface facing the cloud
interface s1/0
Ip address 19.168.116.1/24
interface g1/0
ip address 192.168.16.2/30
router ospf 120
network 192.168.116.0 255.255.255.0 area o
network 192.168.16.0 255.255.255.252 area 20
passive interface default
no passive interface s1/0
no passive interface g1/0
Router# 2
is not connected to the vpls cloud so the statement will be as follows:
interface s1/0
ip address 192.168.116.2/24
interface g1/0
ip address 192.168.16.6/30
router ospf 120
network 192.168.16.4 255.255.255.0 area 21
Switch:
is not diretctly connected to the vpls cloud but uplink connection to the routers and the statement will be as follows:
int g1/0
description connection to router#1
ip adress 192.168.16.1/24
int g1/1
description connection to router#2
ip address 192.168.16.5/24
router ospf 120
network 192.168.16.0 255.255.255.0 area 20
network 192.168.16.4 255.255.255.252 area 21
no passive interface g1/1
Does the concept in the above config correct. As long s they are directly connected to the area 0 which is the ABR router, we can have multiple area and should be fine. Same for Site 2 & 3. Summarize the routes when sending through the advertisement on the ABR router.
Hope I have been able to explain my understanding. Thanks again for your help.
Mehdi.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-21-2009 08:26 AM
Hello Mehdi,
your understanding is correct.
some details are wrong but probably are just typing errors.
area 0 not o.
Note:
the subnet you use on the VPLS cannot be the same used as backbone vlan inside a single site.
I would consider to connect two routers on the VPLS link as a form of redundancy.
You need also to think of what to do if the VPLS link fails.
You may consider a backup solution based on DMVPN over the internet may be just to be able to reach an isolated site when the VPLS link is failed to understand what is happening.
Hope to help
Giuseppe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-22-2009 04:02 AM
Great! Thank you Giuseppe. I will give it a try.
Regards and thanks for helping me out.
