VPN Between two CISCO 877 Routers
simonsellen
Trying to set up a very simply IPSec VPN connection from my Head Office to a couple of remote sites. I want to use CISCO 877 Routers both at head office and at each remote location. This means the head office 877 needs to be set up for multiple VPNs. I already have the CISCO 877 at both ends working as ADSL routers. Does anyone have  a simple configuration that works or can point me in the right direction? I did look at the CISCO manuals and there is mostly good stuff in there but a few things I think are not very clear and therefore confusing.
Thanks very much,
Simon
8 Replies 8
Jeff Van Houten
Level 5
Level 5
Doc Id 41940 is a good reference for DMVPN.
johnlloyd_13
Level 9
Level 9
I've encountered this article about DVTI while studying for my CCNP SECURE. I was able to labbed it flawlessly using couple of our 877s and ran OSPF.
You can use a hub-and-spoke topology and run dynamic routing protocols. Make sure you've got a K9 IOS image.
Hello, Below is the sample configuration for Head Office and Branch Office (Hub and spoke).
Head Office:
hostname HEADOFFICE-RTR
crypto isakmp policy 10
encr aes
hash md5
authentication pre-share
group 2
crypto isakmp key xyz@key address X.X.X.X no-xauth
crypto ipsec transform-set encrypt-des esp-des
crypto map vpn 10 ipsec-isakmp
set peer X.X.X.X
set transform-set encrypt-des
match address 100
interface ATM0
description ADSL Connected to ISP
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 0/35
  pppoe-client dial-pool-number 1
interface Vlan1
description Head Office LAN
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Dialer0
crypto map vpn
ip route 0.0.0.0 0.0.0.0 Dialer0
ip nat inside source list 101 interface Dialer0 overload
access-list 100 permit ip 192.168.1.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 101 deny   ip 192.168.1.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
Branch Office:
hostname BRANCH-RTR
encr aes
hash md5
group 2
crypto isakmp key xyz@key address Y.Y.Y.Y no-xauth
set peer Y.Y.Y.Y
match address 100
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
pvc 0/35
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip nat inside
interface Dialer0
crypto map vpn
access-list 100 permit ip 10.10.10.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 deny   ip 10.10.10.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
Hello ,
You will found the toplogy of DMVPN in attached .zip file  using GNS3  with two Spokes and Hub .
Thank you very much for your replies, most helpful even though it is not working yet.
I don't understnad this line:
What do I set for the IP address? in the recommended article, Doc Id 41940, it has it as 0.0.0.0 as ip address.
Also, what would I have to do to add more than one spoke on the hub?
Simon
Here is the configuration for the SPOKE:
version 12.4
no service pad
hostname SPOKE
boot-start-marker
boot-end-marker
enable secret 5 xxxxxx
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.254
ip dhcp pool DHCP_POOL
   import all
   network 192.168.2.0 255.255.255.0
   dns-server 87.194.255.154 87.194.255.155 8.8.8.8
   default-router 192.168.2.254
ip name-server 87.194.255.154
ip name-server 87.194.255.155
ip name-server 8.8.8.8
username xxxxx
crypto isakmp key xxxxx address 0.0.0.0 0.0.0.0
crypto ipsec transform-set trans2 esp-des esp-md5-hmac
mode transport
crypto map vpnmap1 local-address ATM0.1
crypto map vpnmap1 10 ipsec-isakmp
set peer 94.193.xx.xxx
set transform-set trans2
match address 101
archive
log config
  hidekeys
bridge irb
interface Tunnel10
bandwidth 1000
ip address 10.0.0.2 255.255.255.0
ip mtu 1400
delay 1000
tunnel source ATM0.1
tunnel destination 94.193.xx.xxx
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
dsl operating-mode adsl2+
description Link to BE
ip address 188.220.xx.xx 255.255.248.0
ip nat outside
atm route-bridged ip
pvc 0/101
  encapsulation aal5snap
crypto map vpnmap1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
no ip address
bridge-group 1
interface BVI1
description Local LAN
ip address 192.168.2.254 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 188.220.xx.xx
ip route 192.168.1.0 255.255.255.0 Tunnel10
ip http server
no ip http secure-server
ip nat inside source list 1 interface ATM0.1 overload
ip nat inside source static tcp 192.168.2.250 22 interface ATM0.1 22
ip nat inside source static tcp 192.168.2.250 21 interface ATM0.1 21
ip nat inside source static tcp 192.168.2.250 20 interface ATM0.1 20
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 101 permit gre host 188.200.xx.xx host 94.193.xx.xxx
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0
password xxx
login
line vty 1 4
login
scheduler max-task-time 5000
end
Can anyone see what the problem is?
On the hub the 0.0.0.0 address indicates that you will accept connections from any external DMVPN client that presents the proper authentication credentials.
oh ok, thanks for this, makes sense. On the hub I now have this configuration:
version 12.4
no service pad
hostname HUB
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-3208576596
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3208576596
revocation-check none
rsakeypair TP-self-signed-3208576596
crypto pki certificate chain TP-self-signed-3208576596
certificate self-signed 01 nvram:IOS-Self-Sig#3.cer
dot11 syslog
ip cef
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
   import all
   network 10.10.10.0 255.255.255.248
   default-router 10.10.10.1
   lease 0 2
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.254
ip domain name yourdomain.com
username xxxx privilege 15 secret xxxxx
crypto isakmp key ciscotest address 188.220.xx.xx
mode transport
set peer 188.220.xx.xx
match address 101
archive
log config
  hidekeys
bridge irb
interface Tunnel1
bandwidth 1000
ip address 10.0.0.1 255.255.255.0
ip mtu 1400
delay 1000
tunnel destination 188.220.xx.xx
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip address 94.193.xx.xxx 255.255.254.0
ip nat outside
pvc 0/101
crypto map vpnmap1
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0        54.0
station-role root
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
description my local range
ip nat inside
ip route 0.0.0.0 0.0.0.0 94.193.xx.xx
ip route 192.168.2.0 255.255.255.0 Tunnel1
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 101 permit gre host 94.193.xx.xxx host 188.220.xx.xx
no cdp run
control-plane
bridge 1 route ip
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
end
Also, I think you need to read through the entire document. It looks like you've got old style point to point IPSec commands in there. There's no Nhrp at all, tunnel config doesn't look right, etc.
