VPN client gets connected but cannot ping LOCAL LAN
khizerkhan
Dear All,
I am trying to connect my 2800 Series CIsco Office router with VPN client software from home. I can successfully authenticate and get the IP address from the pool configured  but couldnt ping any LAN Ips including default gateway. I am pasting my router's configuration. Any urgent help would be really appreciated:
IP Address Of LAN: 192.168.22.x/ 24
IP Addresses handed out to Clients: 10.10.10.5- 10.10.10.20
aaa new-model
aaa authentication login default local
aaa authentication login future_tech local
aaa authorization exec default local
aaa authorization network ft-network local
username ftvpn privilege 15 password 7 047E11301F2F
crypto isakmp policy 20
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group  ft-network
key x.x.x.x
dns 202.125.148.x 8.8.8.x
domain future.com.pk
pool ft_pool
save-password
max-users 10
netmask 255.255.255.0
crypto isakmp profile ISAKMP_PRO
   match identity group ft-network
   client authentication list future_tech
   isakmp authorization list ft-network
   client configuration address respond
   virtual-template 100
crypto ipsec transform-set easy_vpn esp-3des esp-sha-hmac
crypto ipsec profile IPSEC_PRO
set security-association idle-time 86400
set transform-set easy_vpn
set isakmp-profile ISAKMP_PRO
interface Multilink1
description WAN INTERFACE
ip address y.y.y.y 255.255.255.248
ip verify unicast reverse-path
ip inspect SDM_LOW out
ip nat outside
ip virtual-reassembly
no cdp enable
ppp multilink
ppp multilink group 1
interface GigabitEthernet0/1
description LAN INTERFACE
ip address z.z.z.z 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface Virtual-Template100 type tunnel
ip unnumbered GigabitEthernet0/1
tunnel mode ipsec ipv4
tunnel protection ipsec profile IPSEC_PRO
ip nat inside
ip local pool ft_pool 10.10.10.5 10.10.10.20
ip route 0.0.0.0 0.0.0.0 Multilink1
access-list 120 deny   ip 192.168.22.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 120 permit ip 192.168.22.0 0.0.0.255 any
ip nat inside source list 120 interface Multilink1 overload
I have noticed that my virtual-access interface comes up but the line protocol of virtual-interface remains down as follows:
Virtual-Template100        x.x.x.x YES TFTP   up                    down
Also The client PC picks up a random gateway of 10.10.10.1 which I never configured anywhere on the server.
KhiZ
28 Replies 28
Abzal
Level 7
Level 7
Refer this link
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800949db.shtml
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Dear Abzal,
Thanks for your reply. I have seen the link and what I understand from the diagram is that the Client PC is also having a public address which is not in my case. I only have one Public IP Address which is applied on a multilink Interface. Iam successfully able to authenticate and get the IP Address from the address pool but having the following problems:
1. I cannot ping the LAN Interface where I have applied IP NAT INSIDE.
2. I cannot ping any LAN Devices behind that LAN Interface.
3. My virtual-access interface is up and up in Sh ip int br, but Virtual-template is up and down.
4. On PC with VPN Client, I am getting a default gateway of 10.10.10.1 even though I have not configured it anywhere on my server.
Please take a look at the config I attached.
aaa new-model
encr 3des
group 2
key x.x.x.x
pool ft_pool
save-password
max-users 10
ip nat outside
no cdp enable
ppp multilink
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
ip nat inside
You need to add Split tunnel ACL. As connection is established, server may create a static route,  corresponding to the client VPN IP address using process know as Reverse  Route Injection (RRI).
access-list 110 permit ip 192.168.22.0 0.0.0.255 any
key x.x.x.x
pool ft_pool
save-password
max-users 10
acl 110
ip unnumbered Multilink1
no ip nat inside
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6635/ps6659/prod_white_paper0900aecd80313bf8.pdf
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Dear Abzal,
Thanks for writing in. Is this acl 110 under crypto client config group means that this traffic will be encrypted by IPSEC ??
Also is it necessary to use public IP on virtual template interface without IP NAT inside; as I have read on another discussion that Virtual-template interface should have an IP address of any LAN interface with IP NAT inside configured.
Yes, split tunnel ACL is correct, but you can configure it to be more specific by configuring the vpn client pool as the destination:
access-list 110 permit ip 192.168.22.0 0.0.0.255 10.10.10.0 0.0.0.255
Also with Virtual-Template, you can use either private or public ip address for "ip unnumbered" just to bring the interface up.
Multilink is probably a good idea because if your multilink interface is down, then you won't be able to VPN in anyway.
Dear Jennifer,
Thanks for your reply. I have done exactly what you said but unfortunately I am not able to ping anything including my Routers LAN interface (192.168.22.199). There is no firewall or anything that is blocking; I am successfully able to connect and client gets the IP from the pool but still no luck with acccessing the LAN network. Following is my configuration:
aaa new-model
encr 3des
group 2
crypto isakmp keepalive 10
key x.x..x.x
dns 202.125.148.x 8.8.x.x
pool ft_pool
acl SPLIT_TUNEL
save-password
max-users 10
no ip redirects
no ip proxy-arp
ACL used for Not NATTING the traffic between 192.168.22.x and 10.10.10.x networks as some static mappings are already configured
ip access-list extended DENY_NAT
Split tunnel ACL for encryption of interested Traffic
ip access-list extended SPLIT_TUNEL
ip nat inside source list DENY_NAT interface Multilink1 overload
ip route 10.10.10.0 255.255.255.0 multilink1 (Interface with the Public IP Address assigned)
ip address  pUBLIC IP
ip nat outside
no cdp enable
ppp multilink
ip address 192.168.22.199 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
end
From VPN SERVER
FTNet#show crypto isakmp sa
dst             src             state          conn-id slot status
x.x.x.x  119.157.184.65  QM_IDLE              1    0 ACTIVE
FTNet#show crypto ipsec sa
interface: Virtual-Access2
    Crypto map tag: Virtual-Access2-head-0, local addr x.x.x.x
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
   remote ident (addr/mask/prot/port): (10.10.10.9/255.255.255.255/0/0)
   current_peer 119.157.184.65 port 62365(IP Add of my EVO Dongle)
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
Following are the images of CISCO VPN Client used on Windows 7 64-bit machine:
http://tinypic.com/r/2vd5lbt/6
http://i50.tinypic.com/vqns7q.jpg
Hi Muhammed,
Can you show routing table from VPN client while it's connected to VPN server?
route print
And traceroute:
tracert 192.168.22.199
Once VPN client connected check the router if there is a route through VTI to remote network:
sh ip route
sh crypto route
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Dear Abzal,
I am getting incosistent results. Some times I am able to ping the LAN gateway and most of the time I doesnt: Anyways following is what you asked for:
C:\Users\nadeem>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection 3:
   Connection-specific DNS Suffix  . : future.com.pk
   Link-local IPv6 Address . . . . . : fe80::18b:5440:e353:5ad%43
   IPv4 Address. . . . . . . . . . . : 10.10.10.19
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . :
C:\Users\nadeem>route pr
Manipulates network routing tables.
ROUTE [-f] [-p] [-4|-6] command [destination]
                  [MASK netmask]  [gateway] [METRIC metric]  [IF interface]
  -f           Clears the routing tables of all gateway entries.  If this is
               used in conjunction with one of the commands, the tables are
               cleared prior to running the command.
  -p           When used with the ADD command, makes a route persistent across
               boots of the system. By default, routes are not preserved
               when the system is restarted. Ignored for all other commands,
               which always affect the appropriate persistent routes. This
               option is not supported in Windows 95.
  -4           Force using IPv4.
  -6           Force using IPv6.
  command      One of these:
                 PRINT     Prints  a route
                 ADD       Adds    a route
                 DELETE    Deletes a route
                 CHANGE    Modifies an existing route
  destination  Specifies the host.
  MASK         Specifies that the next parameter is the 'netmask' value.
  netmask      Specifies a subnet mask value for this route entry.
               If not specified, it defaults to 255.255.255.255.
  gateway      Specifies gateway.
  interface    the interface number for the specified route.
  METRIC       specifies the metric, ie. cost for the destination.
All symbolic names used for destination are looked up in the network database
file NETWORKS. The symbolic names for gateway are looked up in the host name
database file HOSTS.
If the command is PRINT or DELETE. Destination or gateway can be a wildcard,
(wildcard is specified as a star '*'), or the gateway argument may be omitted.
If Dest contains a * or ?, it is treated as a shell pattern, and only
matching destination routes are printed. The '*' matches any string,
and '?' matches any one char. Examples: 157.*.1, 157.*, 127.*, *224*.
Pattern match is only allowed in PRINT command.
Diagnostic Notes:
    Invalid MASK generates an error, that is when (DEST & MASK) != DEST.
    Example> route ADD 157.0.0.0 MASK 155.0.0.0 157.55.80.1 IF 1
             The route addition failed: The specified mask parameter is invalid
(Destination & Mask) != Destination.
Examples:
    > route PRINT
    > route PRINT -4
    > route PRINT -6
    > route PRINT 157*          .... Only prints those matching 157*
    > route ADD 157.0.0.0 MASK 255.0.0.0  157.55.80.1 METRIC 3 IF 2
             destination^      ^mask      ^gateway     metric^    ^
                                                         Interface^
      If IF is not given, it tries to find the best interface for a given
      gateway.
    > route ADD 3ffe::/32 3ffe::1
    > route CHANGE 157.0.0.0 MASK 255.0.0.0 157.55.80.5 METRIC 2 IF 2
      CHANGE is used to modify gateway and/or metric only.
    > route DELETE 157.0.0.0
    > route DELETE 3ffe::/32
C:\Users\nadeem>tracert 192.168.22.199
Tracing route to 192.168.22.199 over a maximum of 30 hops
  1    36 ms    33 ms    34 ms  192.168.22.199
Trace complete.
At this time I was able to ping only the default gateway but not any other IP. When I am also not able to ping gateway; traceroute shows only *
C:\Users\nadeem>
Ok, I see
try now to trace any host on the LAN behind router
traceroute 192.168.22.X
And the correct command is
route print
not route pr
And on the router:
show crypto route
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Dear Abzal,
Following is the information you asked for: at the time I am unable to ping the default gateway:
C:\Users\nadeem> ipconfig
   Link-local IPv6 Address . . . . . : fe80::18b:5440:e353:5ad%35
   IPv4 Address. . . . . . . . . . . : 10.10.10.5
C:\Users\nadeem>ping 192.168.22.199
Pinging 192.168.22.199 with 32 bytes of data:
Request timed out.
Ping statistics for 192.168.22.199:
    Packets: Sent = 1, Received = 0, Lost = 1 (100% loss),
Control-C
^C
  1     *        *        *     Request timed out.
  2     *        *        *     Request timed out.
  3  ^C
C:\Users\nadeem>route print
Interface List
35...00 05 9a 3c 78 00 ......Cisco Systems VPN Adapter for 64-bit Windows
22...00 1e 10 1f 79 c9 ......HUAWEI Mobile Connect - 3G Network Card
19...00 ff 58 bd 48 9a ......Spotflux Network Device Driver
13...00 23 14 51 5d c5 ......Microsoft Virtual WiFi Miniport Adapter #2
12...00 23 14 51 5d c5 ......Microsoft Virtual WiFi Miniport Adapter
11...00 23 14 51 5d c4 ......Intel(R) Centrino(R) Advanced-N 6200 AGN
10...54 42 49 0d 0d fb ......Marvell Yukon 88E8059 PCI-E Gigabit Ethernet Contr
oller
20...00 50 56 c0 00 01 ......VMware Virtual Ethernet Adapter for VMnet1
21...00 50 56 c0 00 08 ......VMware Virtual Ethernet Adapter for VMnet8
  1...........................Software Loopback Interface 1
28...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
29...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
34...00 00 00 00 00 00 00 e0 Microsoft 6to4 Adapter
30...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #4
25...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #5
16...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
31...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #6
27...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #7
32...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #8
24...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #9
33...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #10
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0      192.168.0.5      192.168.0.3    281
          0.0.0.0          0.0.0.0   119.157.188.41   119.157.188.42    296
       10.10.10.0    255.255.255.0         On-link        10.10.10.5    281
       10.10.10.5  255.255.255.255         On-link        10.10.10.5    281
     10.10.10.255  255.255.255.255         On-link        10.10.10.5    281
   119.157.188.40  255.255.255.252         On-link    119.157.188.42    296
   119.157.188.42  255.255.255.255         On-link    119.157.188.42    296
   119.157.188.43  255.255.255.255         On-link    119.157.188.42    296
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
      192.168.0.0    255.255.255.0         On-link       192.168.0.3    281
      192.168.0.3  255.255.255.255         On-link       192.168.0.3    281
      192.168.0.5  255.255.255.255         On-link       192.168.0.3    100
    192.168.0.255  255.255.255.255         On-link       192.168.0.3    281
     192.168.22.0    255.255.255.0       10.10.10.1       10.10.10.5    100
     192.168.31.0    255.255.255.0         On-link      192.168.31.1    276
     192.168.31.1  255.255.255.255         On-link      192.168.31.1    276
   192.168.31.255  255.255.255.255         On-link      192.168.31.1    276
    192.168.142.0    255.255.255.0         On-link     192.168.142.1    276
    192.168.142.1  255.255.255.255         On-link     192.168.142.1    276
  192.168.142.255  255.255.255.255         On-link     192.168.142.1    276
  221.120.193.212  255.255.255.255      192.168.0.5      192.168.0.3    100
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    306
        224.0.0.0        240.0.0.0         On-link     192.168.142.1    276
        224.0.0.0        240.0.0.0         On-link      192.168.31.1    276
        224.0.0.0        240.0.0.0         On-link    119.157.188.42    296
        224.0.0.0        240.0.0.0         On-link       192.168.0.3    281
        224.0.0.0        240.0.0.0         On-link        10.10.10.5    281
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    306
  255.255.255.255  255.255.255.255         On-link     192.168.142.1    276
  255.255.255.255  255.255.255.255         On-link      192.168.31.1    276
  255.255.255.255  255.255.255.255         On-link    119.157.188.42    296
  255.255.255.255  255.255.255.255         On-link       192.168.0.3    281
  255.255.255.255  255.255.255.255         On-link        10.10.10.5    281
Persistent Routes:
  Network Address          Netmask  Gateway Address  Metric
          0.0.0.0          0.0.0.0       20.20.20.1  Default
IPv6 Route Table
Active Routes:
If Metric Network Destination      Gateway
  1    306 ::1/128                  On-link
34   1040 2002::/16                On-link
34    296 2002:1414:1464::1414:1464/128
                                    On-link
34    296 2002:779d:bc2a::779d:bc2a/128
                                    On-link
20    276 fe80::/64                On-link
21    276 fe80::/64                On-link
11    281 fe80::/64                On-link
35    281 fe80::/64                On-link
30    286 fe80::5efe:192.168.0.3/128
                                    On-link
35    281 fe80::18b:5440:e353:5ad/128
                                    On-link
25    296 fe80::200:5efe:119.157.188.42/128
                                    On-link
21    276 fe80::7063:e48e:2976:ea9b/128
                                    On-link
20    276 fe80::ccc3:3d59:7b60:dde8/128
                                    On-link
11    281 fe80::f141:928f:6bf9:f6f/128
                                    On-link
  1    306 ff00::/8                 On-link
20    276 ff00::/8                 On-link
21    276 ff00::/8                 On-link
11    281 ff00::/8                 On-link
35    281 ff00::/8                 On-link
Persistent Routes:
  None
C:\Users\nadeem>
From VPN Server
FTNet#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S       10.10.10.5/32 [1/0] via 0.0.0.0, Virtual-Access2
C       10.255.211.1/32 is directly connected, Loopback0
S       10.111.1.0/24 [1/0] via 192.168.22.197
S       10.101.0.0/16 [1/0] via 192.168.22.197
S       10.116.0.0/16 [1/0] via 192.168.22.197
There is no command show crypto route on my IOS; so I used the following
FTNet#show crypto sess
Crypto session current status
Interface: Virtual-Access2
Session status: UP-ACTIVE
Peer: 39.48.78.131 port 12003
  IKE SA: local x.x.x.x.x/500 remote 39.48.78.131/12003 Active
  IPSEC FLOW: permit ip 0.0.0.0/0.0.0.0 host 10.10.10.5
        Active SAs: 2, origin: crypto map
x.x.x.x.     39.48.78.131    QM_IDLE              1    0 ACTIVE
Config on the router is same as before!!
Ok, let's try this one
route-map nonat permit 10
match ip add DENY_NAT
ip nat inside source route-map nonat interface Multilink1 overload
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Well this easy VPN doesnt seem so easy. Still the same result however I noticed the following on VPN SERVER
221.120.193.212 39.48.78.131    QM_IDLE              1    0 ACTIVE ISAKMP_PRO
Its showing ISAKMP_PRO; the isakmp profile that I created. Previously it shows just active:
show ip route
       10.10.10.6/32 [1/0] via 0.0.0.0, Virtual-Access3
   IPv4 Address. . . . . . . . . . . : 10.10.10.6
Still cant ping the default gateway!!
I also noticed on most of the Cisco examples on cisco website that they have used the similar pool which is used on the LAN. Just a thought. I tried that as well and it didnt worked
I also noticed that when I remove split-tunnel ACL; the counters on VPN client software begin to increase but still I  couldnt ping the default gateway. Snapshot is attached:
http://i49.tinypic.com/15wnjas.jpg
From VPN Server:
   remote ident (addr/mask/prot/port): (10.10.10.7/255.255.255.255/0/0)
   current_peer 39.48.78.131 port 13796
    #pkts encaps: 8, #pkts encrypt: 8, #pkts digest: 8
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: x.x.x.x, remote crypto endpt.: 39.48.78.131
     path mtu 1500, ip mtu 1500, ip mtu idb Multilink1
     current outbound spi: 0x6F81FEBC(1870790332)
     inbound esp sas:
      spi: 0x96E19D7E(2531368318)
        transform: esp-3des esp-sha-hmac ,
        in use settings ={Tunnel UDP-Encaps, }
        conn id: 3001, flow_id: NETGX:1, crypto map: Virtual-Access2-head-0
        sa timing: remaining key lifetime (k/sec): (4496251/2648)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE
